About the article: https://www.stereophile.com/content/loudspeaker-designer-john-dunlavy-numbers
It's an interesting article that I read many years ago. I had forgotten the issues he brought up about step and impulse responses when going from 1st order to 2nd, 3rd, and 4th order passive XOs. I never worried about it. Using a different type of transducer technology fixed the problem, by removing damping issues altogether if you use small single or redundant planars and ribbons. You don't have to worry about beaming or overshoot as long as you stay within the suggested, confirmed, and tested parameters.
Dunlavy's approach to IB cabinets is also quite interesting. Specifically, boom in the room and boom from a particular type of speaker/cabinet design. If you
mechanically adjust for boom,
the issue becomes an asset, not a PITA as he suggests, but as in all things, we live, and we learn. His later implementation of DSP completely removed all the felt from the front baffle and the stepped front baffle design.
Personal note: It cost a lot less for the latter design and aesthetically the hard line look and about 2/3s of the 550lb original IV weight with the same results. It's also one of the few HUGE speakers that make music in accordance to the music being played. Those huge speaker cabinets work quite well in a very small room.
The whole diffraction (by and large) question is way overplayed when simple roundovers are the answer with the current CnC's ability and the cost to use it. Heck, a good router table or jointer for a larger project WILL blow the whole
felt thing out the door. I quit using felt on drivers' baffles 20+ years ago.
First: I'd doubt that he has a copyright, and much more likely, he has a patent if he has any protection at all. Second: even if he has patents
he, NOT THE GOVERMNENT has to enforce those rights in civil court.
FYI:
Patents.
Please Google how long patents are enforceable.
Patent protection lengths vary by type, with
Utility patents (inventions, processes) generally lasting
20 years from the filing date,
Plant patents also lasting
20 years from filing, and
Design patents (ornamental look) lasting
15 years from the grant date (for applications filed after May 13, 2015). Utility patents require maintenance fees to stay active, while design patents generally do not.
By Patent Type
- Utility Patents: 20 years from the earliest non-provisional filing date, provided maintenance fees are paid.
- Design Patents: 15 years from the date the patent is granted (for applications filed on or after May 13, 2015).
- Plant Patents: 20 years from the application filing date, with no maintenance fees.
Key Considerations
- Filing Date: The clock generally starts ticking from the application filing date, not the issue date, for utility and plant patents.
- Maintenance Fees: For utility patents, failing to pay periodic maintenance fees will cause the patent to expire prematurely.
- No Renewal: Once a patent term ends, it cannot be renewed; the invention enters the public domain.
Copyrights
Please Google, "How long are copyrights enforceable?"
In the U.S., copyright generally lasts for the life of the author plus 70 years for works created after 1978; for corporate works, anonymous, or pseudonymous works, it's 95 years from publication or 120 years from creation, whichever is shorter, with older works having different, often complex, durations based on their publication dates. After this period, the work enters the public domain, becoming free for anyone to use.
For Works Created On or After January 1, 1978 (U.S.)
- Individual Authors: Life of the author + 70 years after their death.
- Joint Works: 70 years after the last surviving author's death.
- Works Made for Hire, Anonymous, or Pseudonymous Works: 95 years from publication or 120 years from creation, whichever ends first.
For Works Created Before 1978 (U.S.)
- These have varying terms, often involving an initial 28-year term, with an optional 67-year renewal, totaling 95 years if renewed.
- Many works published between 1929 and 1977 now fall into the public domain or have extended terms, with specific dates depending on publication year.
Key Factors Determining Duration
- Date of Creation/Publication: The year the work was fixed in a tangible form or first published is crucial.
- Type of Work: Individual vs. corporate/anonymous authorship changes the rules.
- Country: While the U.S. follows these rules, other countries (like the EU) have similar life+70 rules but varying specifics.
When Does it Become Public Domain?
- Once the copyright term expires, the work enters the public domain, meaning it can be used freely by anyone without permission.
Regards
