olds1959special
Mogami 2964
RG58 is very similar to RG6 (or RG59) and is essentially equivalent for audio cables. RG6 is very commonly used for video cables, has slightly less loss at RF frequencies (decades above the audio band), and handles more current, mainly a consideration for satellite dishes that send DC along the cable to power the amplifier mounted on the dish. For audio, RG6 is overkill, and is thicker and stiffer than RG58 (50 ohm) or RG59 (75 ohm) cables that are commonly used for audio RCA cables. The copper braid shield is typically 90~95% coverage, plenty for audio, and is more resistant to damage from flexing than the 100% foil shield typical of RG6.@DonH56 - I too prefer using pure copper. However, I need eight RCA cables where each cable will be 6 feet long. I am thinking of making the cables myself because I think it will be fun. Bought decent solderless RCA connectors and I have a whole roll of RG58C/U coaxial cable which I never used.
Just to clarify, I need the 8 RCA cables specifically for audio only.
A quick google search revealed the following about the cable I have:-
RG58C/U is a 50-ohm coaxial cable commonly used for radio frequency (RF) and low-power signal connections. It's characterized by its stranded tinned copper conductor, polyethylene (PE) insulation, and tinned copper braid shield. The outer jacket is typically made of black PVC.
Ultimately, is it better for me to purchase RG6 cable for better shielding and to avoid compromising audio fidelity?
Short answer: RG58 is fine, better than RG6 for you, so use it and be happy.
HTH - Don
25 ohms!?!?!?! Have not heard that, but since there are so many different "flavors" of RCAs, who knows? The ones I have measured have been around 75 ohms but it was originally designed as an audio, not RF, connector and so RF impedance was never part of the original spec AFAIK. Not until they stuck with it for video cables, probably for a cheap connector they already had vs. any real desire for signal integrity, did the RCA become "specified" for 75-ohm cables. I have measured anywhere from around 50 or 60 ohms up to maybe 80 or 90 ohms but have not measured them all -- not a thing for me since the RF connectors I used were generally rated for higher range and needed much better capture and RF characteristics. I am not even a fan of BNCs; they tend to get loose over time, and there's no way to make (and keep) them hermetic (though some specialized versions exist, e.g. HP/Agilent/Keysight versions). Folk get away with RCAs on video cables because they are cheap and the discontinuity is usually short enough to not cause big problems, especially given the relatively high signal level and short cable runs.Adding to the the discussion of ohm ratings for the various RGs, I recall when I was researching my DIY article on making your own cables, I came across something that claimed RCAs are 25 ohm connectors! Kinda puts all those concerns about the cables to bed, doesn't it?
Regards,
Wayne A. Pflughaupt
This is extremely important if you want to pass microwave frequencies.Below are some coaxial cable characteristic impedance calculators to assist in making a rudimentary determination of the impedance of your RCA connectors. To use them you will have to sacrifice at least one connector to determine the insulator diameter and the material. Deciding what the insulator material is will be the most difficult part. Just remember, that for our frequencies of interest, characteristic impedance does not matter.
https://www.pasternack.com/t-calculator-coax-cutoff.aspx
https://www.everythingrf.com/rf-calculators/coaxial-cable-calculator
I posted a less than comprehensive list of Belden, and a few other manufacturer's, coaxial cables that could be used for interconnects along with some construction tips in another discussion.
A new entry in the Belden product line is Belden 9223 Audio coax.
Just to note, I'm not shilling for Belden. The examples given were to illustrate some coaxial cable types that could be used and Belden provides specs for their cable that many manufacturers do not.
I posted some comparative measurements of a few cable samples to magnetic interference from an AC transformer in another old discussion. Make of them what you will.
RF Impedance is irrelevant at audio frequencies. The only thing that matters is resistance, inductance, and capacitance (RLC) and for interconnects among local components even those do not matter since lengths are short. Companies like Belden, Gore, and Suhner provide that data for their cables.Below are some coaxial cable characteristic impedance calculators to assist in making a rudimentary determination of the impedance of your RCA connectors. To use them you will have to sacrifice at least one connector to determine the insulator diameter and the material. Deciding what the insulator material is will be the most difficult part. Just remember, that for our frequencies of interest, characteristic impedance does not matter.
No. And major disadvantages. Neither are optimal, but RG-6 is considerably stiffer and harder to handle. Unless you're trying to transmit VHF or UHF, you'd do far better with a very hum-drum flexible vinyl-insulated cable.Thank you everyone for your kind and informative responses.
Is there any benefit to using RG-6 over RG-58 for a 6 foot RCA cable?
No, both will work fine, RG-58 is more flexibleThank you everyone for your kind and informative responses.
1855a aka mini coax is more flexible then pretty much anything mentioned here and thinner .
At the usual lengths, the estimated level drop is 0.0002dB - as opposed to the superb 0.00015 you get from pure copper.
At the usual lengths, the estimated level drop is 0.0002dB - as opposed to the superb 0.00015 you get from pure copper.![]()
