Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Welcome to ASR. There are many reviews of audio hardware and expert members to help answer your questions.
Click here to have your audio equipment measured for free!
Well, I pulled those numbers out of my arse for illustrative purposes, but the difference between CCA and copper in this context is really that low or even less. Besides, even if you lost 0.1 or even 1dB in the cable (which you don't), it wouldn't matter at all in practice.
And indeed, for any line level cable to noticeably act as lowpass, it needs to be really long, way longer than in the usual home stereo scenario. Even music studios and concert installations with cable runs of dozens and sometimes 100-200 meters don't run into that problem. Physics are firmly on our side here.
From an electrical point of view, conductor material is absolutely irrelevant. A few years back, Michael Mardis posted files comparing copper to a potato. Not one person was able to tell them apart in an ABX test.
There is absolutely nothing wrong with that cable for interconnect use. Belden 8262 is the equivalent cable for what you have and is considered mil-spec. Stop worrying and start soldering.
The far most important thing about building your own cables are the means to check them after you're done.
A DMM is mandatory to see if there's any shorts, etc.
Do not measure them only in series but in parallel too, I have seen horror stories this way, no matter the price.
That's actually the single biggest reason why I always make cables, even before price. Too much garbage out there that's shoddily made. Cough Audioquest cough
@Sokel - Thank you for highlighting that. Went through a couple of YouTube videos to understand how to use the infinite resistance technique. Essentially I need to see OL or I displayed on the DMM display when I execute the non-continuity test.
