Multicore
- Joined
- Dec 6, 2021
- Messages
- 3,412
- Likes
- 4,075
The idea is to use an impulse to get a wide spectrum input to see the resonances. I would use a frequency response to display it.Now that might be interesting - effectively measuring the impulse response of the guitar.
You could. When I was studying one of my guitars I learned that the absolute values aren't so important. The shape and relative position of peaks is the most interesting thing: center frequency, dB, and Q.It could even be repeatable if the "mallet" were on a pivot being dropped from a controlled height onto a consistent location on the guitar. (just below the bridge, perhaps)
It depends what you're looking for. OP was talking about comparing only the differences cover plate of the resonator cone make. I guess you could measure it both separately and assembled into the guitar and maybe identify which part produces which detail in the system response. For example with guitar you can damp the top and back separately to see which part is responsible for which peaks. ASR member @bluefuzz has a lot of knowledge and experience in this area.EDIT - I would be tempted to leave the strings open, since they form a significant part of the resonant structure of the guitar. Or at least try both open and muted.
But now I'm thinking that this approach may not be so helpful with a resonator. I would not be surprised to find that non-linear behavior is important in the characteristic sound.
