No options for downsampling?You can make 2 votes, so pleases let us know what rate you upsampe to if you do.
Why would you do this?No options for downsampling?![]()
You have source material over 24/192?In order to use it with higher resolution sources, downsampling is necessary.
As i said almost all DACs up sample those days the question is only do you do it consciously in software or do you let it happen in the "black box" that is your DAC.@Lambda what do you hope to gain by resampling?
Think about watching a DVD on a 4K TV the question is not do you upscale. but do you do it in the player/pc or do you let the TV do its thing.
one is not necessarily better or worse than the other.
Well the question was invalid. I do it because it's necessary to play 44,1khz CDs on modern DACs.That's a non-answer.
Do you have evidence that your equipment is doing something nefarious to your input signal?
Can be != has to be.And one means can certainly be better or worse than another...
because it's necessary to play 44,1khzHow so?
Show me a modern non over sampling dac with good performance.Nonsense.
And showed you evidence that the up sampling filter can make a difference.But, like I suspected, you have no real reason backed by evidence affecting you personally.
Sure. Up to 32/352.8 PCM and DSD256 (in multichannel).You have source material over 24/192?
I did not expect this sorry.
I never came across music in this format!32/352.8
that's another story.DSD256
Why do you care if its effecting me personally?
Then why is it so hard to link to a datasheet?You may be able to find one or two measured on this site.
This would be a good example where its internal up sampler and filter is bad and can be improved by external up sampling. https://www.audiosciencereview.com/forum/index.php?threads/khadas-tone2-pro-review-dac-amp.20684/I was however curious if you have a real problem to solve
