RexrothPigeon
- Joined
- Mar 21, 2025
- Messages
- 1,551
- Likes
- 3,219
no, i'm very sure it's not, but the fact that we will never know if you're right or i'm right says it allI think that’s likely quite exaggerated.
Getting this wrong and then relying on off-axis to compensate is a completely crapshoot.
On-axis neutrality is the most important characteristic of a speaker.
No way can you predict the reflections in anyone's room. Today, many homes have open floor plans, meaning some of the reflections don't even exist!
This is why I keeps saying flat on axis and well behaved off-axis.
f flat on-axis response makes off axis worse, then that is designer's job to fix. Not make on-axis worse as a cure.
I am asking for perfect on-axis, not off-axis. If you can't manage this, then better get out of the kitchen:That is basically impossible, and would translate to a perfect pointsource with perfect constant directivity, which is in combination pretty difficult, if not impossible, to design (for the obvious reason of diaphragms being much bigger than 0, and the variety of audible wavelengths is pretty vast).
I am not advocating constant directivity. Sloping DI is fine with me. It would result in a sloping down overall response which is what is preferred anyway.Or could you name a solution for example of bring a speaker, delivering an overshoot of (lower) midrange compared to brilliance and treble bands due to increasing directivity index, to constant directivity, without compromising on the on-axis response?
I don't mean this as a personal comment, but are you using machine translation? I can't follow half of what you write. "sub summarize?" "most important, may it be?"Let us agree on, it is the easiest one to identify subtle changes in, the best when it comes to finding correlations between listening and measuring, and the first one to notice when listening to unknown material on a new speaker. If you sub summarize that under ´most important´, may it be.
No, that is exactly the point. Sharing subjective impressions is nothing more than a mishmash of adjectives whose efficacy hinges partly on how invested we both are in a shared shorthand lexicon of metaphors ("warm," "clinical," etc.), the old "dancing about architecture" cliche. I just really don't want to learn that stuff or be influenced by it, since it's the stock-in-trade of the grifters and snake oil salesmen and I don't have any need of it anyway.At this point, you may want to say “ but if you’re showing me the measurements that’s all I need” that of course isn’t the point.
Having watched this thread in the last day or so, it appears that the HiFi audio subjectivists are alive and well.
They all came out of hiding from the woodworks cheering on feel, gut, artistic expression and emotions as the anthem of speaker design.
We have gone back few decades of scientific progress with this thread. I bet the next thing to follow is Danny Ritchie to get promoted as the new standard bearer of speaker design.
then the point is arguing against a straw man because "100% random" is not an argument anyone is making hereThe point is rather that the fact that two people are able to share somewhat meaningful information about the sound independently in a sighted listening, implies that what we are able to hear in a sighted listening isn't 100% random.
look, when you have an option that is clear and accurate and not random, and you have another option that is ambiguous and metaphorical and [some frequency] random and [some amount] distorted by inescapable biases, then you take the first option and ignore the second since it will only diminish reliability. that's the situation we find ourselves in today in audio.
Did you notice how the reply you got was a long-winded anecdote that 'sounds logical', laced with hypothetical whataboutisms, but zero valid evidence? Not good enough (but highly characteristic of the denialist's tactical armoury).no, i'm very sure it's not, but the fact that we will never know if you're right or i'm right says it all
Nobody said it is 100% random. You can't be twisting the argument so maliciously by mistake, or simply because you fell for Matt's debating tactics. In fact it is 100% non-random, in that one's cognitive biases will always work in the same directions at any one point in time (they will often evolve over time). There will be a lot of variations between individuals, but then again, there are often common threads among cognitive biases that result in many people being influenced in the same way by the same non-sonic variables. That's not '100% random'.I don't think the point is whether you find it useful to hear subjective remarks on sound. The point is rather that the fact that two people are able to share somewhat meaningful information about the sound independently in a sighted listening, implies that what we are able to hear in a sighted listening isn't 100% random.
´Well-behaved´ is not defined. We could agree on a linear response in all the aforementioned windows hence constant directivity.
Yes, the more closely subjective description resembles information that is better conveyed in graphic or numerical form, the more accurate it is (thus underscoring its pointlessness).It’s perfectly possible to describe the perceived frequency response of a speaker using universal names of frequency ranges (sub, low, low-mid, mid ...) or even frequencies.
How personal is your process ? You seems to be a one man operationIt's not a very large straw man, because some strongly suggests this to be the case.
The entire context of this discussion is loudspeaker development. So if you were a loudspeaker designer (assuming you're not, I don't know), you would develop the speaker exclusively through measurements, presumably working your way towards the best possible on-axis response? And then call it a day?
Say you found yourself in a situation where you had conflicting compromises in the measurements to choose from. Would you select one of them at random unless a panel of listeners conducting double blind tests between the two were available to you? Would you conclude that "I cannot trust my ears, so there is no point of me listening to the speakers to consider which alternative sounds the best." ?
It’s not pointless when measurements (incl. directivity) aren’t available, and it’s also interesting to see how perceived sound relates to measurements (since a lot of audiophiles believe that relationship is very poor).Yes, the more closely subjective description resembles information that is better conveyed in graphic or numerical form, the more accurate it is (thus underscoring its pointlessness).
Thankyou this helps me .The largest study covering this is "A Multiple Regression Model for Predicting Loudspeaker Preference Using Objective Measurements" by Dr. Sean Olive.
If you analyse the study the preferred slopes can be deducted. Conveniently in Vituixcad the preferred slopes can now be set standard as "shadow slopes" so speaker data can be referenced against it.
Example of the Ascilab C8C overlayed: excellent agreement overall.
Neumann KH150: excellent agreement in nearfield, however too little energy from lower treble upwards => good for nearfield, probably a little dark sounding for most in the farfield.
This response is meant as information, not discuss the merits of the study. If anyone wants to do that, take it up with Dr. Sean Olive.
