Can I ask what technique you use for measuring? the bass response is super clean.
There may be an inherent difficulty with that approach, which seems to be touched on by Harwood's experience, noting in particular the very last sentence:
(long quote)
From: "Some factors in loudspeaker quality", H. D. Harwood, Wireless World, May 1976, pages 45–48, 51–54.
It would seem that such vagaries of human perception can be largely removed by accurate measurements of loudspeaker on-axis and off-axis frequency responses (including distortion), supported by an understanding of the typical variations inherent in domestic listening rooms inhabited by users of those same loudspeakers.
"The conclusion therefore was that it is essentially the direct sound which determines the sound quality and not the spherical response. The measurement of frequency response at various angles in a free-field room is therefore a much better indication of performance than the spherical response even when listening in the reverberant field, and this has been confirmed by careful listening tests many times since. ... The sound quality of a loudspeaker is determined much more by the direct response at any given angle than by the spherical integrated response, and at any rate for stereophonic purposes there may well be a degree of omnidirectionality beyond which it is inadvisable to go."
Supporting that approach, Toole noted that:
"It is well-documented that the timbre of voices and musical instruments is mainly dependent upon the amplitude-versus-frequency spectrum of the sounds. Other linear and non-linear effects can be influential but, for simplicity, this discussion will concentrate on the dominant factor. The accurate reproduction of timbre, therefore, requires a wideband, flat and smooth amplitude response. Wide bandwidth is necessary to reproduce all of the sound, flat response is required for neutral spatial balance, and a smooth response is a good indicator of the absence of audible resonances."
"The deviations from a linear, flat amplitude response that can be detected are very small indeed, a few tenths of a dB for low-Q resonances and other wide-bandwidth deviations. The problem in assessing loudspeakers has been that their sound is very much dependent on the listening conditions. Different organisations and different individuals have different views about what constitutes ideal listening conditions."
So, the question seems to be, which hi-fi loudspeaker manufacturer evaluates their loudspeakers in four or five different listening rooms that are representative of the totality of their (discerning) customer base? That seems to be the final frontier, but also an inherently expensive and time consuming one to tackle with any alacrity.
For speakers, I don't see any problem at all with describing them in subjective terms. Speakers sound different after all.I read multiple comments about we audio designers tell stories just to please the crowd or simply for commercial gains. I find this depressing. If I wanted to make money then I would not be designing audio gear. My motivation is to create stuff that I would love to have myself but does not yet exist. I can then only hope that others may like it too.
While measuring, could you also do a measurement with room reflections in your intended listening environment? You mentioned they will not be used near-field? Although there will be a lot of disturbing reflections they can give indications of balance. Like below, Gated 70 cm measurement (blue) with speaker at intended position vs. speaker at intended position and measurement at LP (≈3 m) with "no gating".There can be reasons, for commercial designs for example: the less crossover parts you can get away with without obiously degrading the sound the better for cost management.
Or, you're trying out some configurations in which you are less or not experienced, for example you're adding a rear firing ambiance tweeter which affects sound power.
Good catch, since these will not be used nearfield I did opt to balance out the curves somewhat. I have been listening to them in the nearfield for the past week, can't say anything is bothering me. It's still remarkably flat overall.
I am, among other things, a social scientist, and I have worked with medical professionals on methods of qualitative data collection that are based entirely on subjective experiences. For example, it is necessary to determine how test subjects react physically and psychologically to certain medications. Your point is absolutely valid, but the problem you describe has been known for decades and has been addressed in medicine, particularly in pharmacological research, and, as far as I know, similar principles also apply in acoustic research.In the end, subjective descriptions are meaningful only for the person who generated them and only under the conditions that person had to contend with. Even a couple years later and in another venue, all bets are off for the same person reliably offering the same impression. Every professional speaker designer has to contend with this problem, every single day, and even the best can do so with less-than-ideal effectiveness.
What you say is correct. What I meant was more that since it is possible to hear differences, it is not "wrong" to claim that you hear one thing or the other. Then whether there is any consensus of what, for example, a big (wide dispersion?) and or detailed, bright/shimmering (elevated tweeter?) sound is, we can discuss.This has been covered in the pages of ASR for years.
Yes, speakers sound different. And yes, that difference can be described in subjective terms. The problem is transferring the meaning of the subjective terms from one person to another ... especially for finer differences that are NOT grossly obvious.
One person's subjective description might (and usually does) mean something different to a second listener who is not at the same location (same room) at the same time, especially if the signal being played is not at all the same.
Taking into account that the performance in the bass and upper bass can be subject to the whims of preference, subjective values become problematic for two people comparing notes on bass. Even subjective descriptions of the treble can cause arguments among otherwise well-meaning listeners.
Expand that to thousands of people all over the world, and subjective descriptions can become not only useless, but downright misleading.
(A few years ago, two ASR members argued about their impressions of Focal treble. They weren't dogging each other ... they were serious. The impressions, because they were in opposition, were useless for readers.)
(emphasis mine)Taking into account that the performance in the bass and upper bass can be subject to the whims of preference, subjective values become problematic for two people comparing notes on bass. Even subjective descriptions of the treble can cause arguments among otherwise well-meaning listeners.
www.audiosciencereview.com
Thanks for sharing your insights, from another field, of subjective experiences feeding into scientific advancement.I am, among other things, a social scientist, and I have worked with medical professionals on methods of qualitative data collection that are based entirely on subjective experiences. For example, it is necessary to determine how test subjects react physically and psychologically to certain medications. Your point is absolutely valid, but the problem you describe has been known for decades and has been addressed in medicine, particularly in pharmacological research, and, as far as I know, similar principles also apply in acoustic research.
In medical and pharmacological research, for example, researchers deliberately work with subjective sensations such as pain, discomfort, or well-being, even though these are individual and context-dependent. The key is not to attempt to eliminate subjectivity, but to structure it in a way that makes it comparable. This is achieved through standardized control groups whose composition is clearly defined and whose members, in some studies, develop a shared understanding of scales and terms, and whose judgments are collected under controlled conditions, such as through randomization and blinding of the samples. In this way, individual perception is transformed into a data type that becomes statistically significant and scientifically analyzable.
The underlying scientific principle is that while individual judgments are not very reliable on their own, aggregating them under controlled conditions yields stable patterns. Subjectivity is thus operationalized in a way that makes it manageable and reproducible, and this is precisely the crucial step from individual experience to scientifically verifiable and usable knowledge.
From what I have read so far, this principle is also reflected in acoustic research when listening tests are conducted according to established standards and listeners are specifically trained to develop a consistent and comparable vocabulary for the parameters being evaluated, with the testing deliberately conducted in a blind or double-blind manner to minimize expectation effects. As in medicine and pharmacology, the results are then not interpreted as the opinions of individuals, but are statistically analyzed and correlated with measurable parameters.
So, these are entirely subjective impressions, but taken together and with enough training (not required in all studies), they become scientifically reliable and sufficiently verified data.
As for what “sufficiently” means, you’ll have to read the package insert—though that’s probably not necessary for speakers.
Fantastic comment! I’ve worked in similar fields to yours and, sadly, I started in the audiophoolery field. It was only when I decided to use the same or similar strict criteria from my professional work that I was able to quickly change my mind. I look at my old days in horror. Now I’m just trying to sell as much of my old equipment as I can and enjoy my simplified and much cheaper equipment.I am, among other things, a social scientist, and I have worked with medical professionals on methods of qualitative data collection that are based entirely on subjective experiences. For example, it is necessary to determine how test subjects react physically and psychologically to certain medications. Your point is absolutely valid, but the problem you describe has been known for decades and has been addressed in medicine, particularly in pharmacological research, and, as far as I know, similar principles also apply in acoustic research.
Within a minute or so, the viewer becomes accustomed to the new look.
Many parallels here with sound in my mind.
When we hear the term "voicing", I'm wondering whether it really means getting the speaker to reproduce well (naturally) all of the the voices such as Soprano, Mezzo-soprano, Alto, Contralto, Tenor, Baritone, or Bass. Or is it simply the application of parametric equalisation to suit someone's preferences on their set of preferred test track(s) in their preferred listening environment based on a few ad hoc listening sessions?At the end of the day, it doesn't seem unreasonable that the speaker has to sound "right/good" to the designer...and that they believe it has a chance of commercial success.
