What role should listening play in speaker design
Status
Not open for further replies.
Yes, the problem is that ruler flat on-axis doesn't tell us everything we need to know.
This is true. For the sake of others (non-members) who might be browsing this thread, it is my position (and the position of many others) that one singular test is quite insufficient to characterize the complex envelope of speaker characteristics. Instead, many different tests need to be performed, and the conclusions based on the total, not just one particular test.
We might be crazy, but we're not that crazy. :D:D
I'll let you know. Here's a 5" +1" sealed monitor to be used with a subwoofer as a living room TV setup. It has a hybrid crossover where the passive components handle the crossover, and DSP is used to shape the signal (like the JBL 7-series). Measurements were made, quick active crossover tested to verify the measurements under a couple of vertical angles. Now I'm assembling the crossover and when finished will make another couple of measurements to verify the results. I don't think much, if any, tweaking will happen - although it would be easy to do so.
looks rad man how much did it cost overall
As a DIYer I certainly did not design my speakers without measurements. Measurements were also used for trouble shooting. Ending up with a not perfect linear response was a compromise due to the flawed stereo system. There is no real contradiction of Toole's work regarding those flawed stereo errors, he also agrees that they are results of a flawed system. You can accept them as they are, or choose to tailor the response a bit to reduce the errors, but not remove them completely. Whether the errors are already compensated in the recording is a matter of debate, especially since both near field listening vs far-field exist in the studios. To a certain extent perhaps.
What is this thread even about lol, even the video at the beginning is lacking bearing... is this the snake oil energy spear heading a revolt against the age of enlightenment?
Measurements are an analysis of what's happening, there's no guarantee that you will be able to interpret what you are looking at or that you are reviewing the correct measures... Measurements in situ and measurements resembling more anechoic, like outside or gated, far vs near, etc, its all apart of the game. If its too much for you to grasp, keep studying. In the end you only have, to gain. The smartest thing you could do is go find an old Scientist, and ask what he/she thinks...
This is a problem of society not audio. You have forgotten who the real professionals are and you've not glorified your elders.... The ones who studied Truth, for a life time, not the ones who study/create lies....
It's been hacked off an Andrew Jones thread and apparently spliced onto another pre-existing one.
From memory (approximate numbers):
Drivers: €400
passive crossover: €100
MDF/paint/screws/terminals/cable: €100
So €600 + amplifier/DSP.
On a topic related note: I've been listening to them in a nearfield setup for the last few days - have not had to make any adjustments to the filter as designed based on the measurements. Everything was done in vituixcad. The new shadow slopes for recommended LW/PIR/SP are super convenient.
Standard 2-way systems are quite predictable of course..
I finally actually listened to the interview with AJ in the first post.
I'm not sure I can say I disagree with much of what he said. Put differently, I agree with most of what he said. :)
Designing speakers without measuring is analogous to crossing a cattle lot in the dark without stepping in cow sh*t.
It's possible, I suppose, but not very likely.
But no one has so far suggested that this is something one should do either. :)
I think one thing people miss when it comes to frequency response is how subjective perception relative to FR is not really linear. This is something I noticed while sourcing / demoing / tuning headphones (by ear, gross) for several hours a day.
In short, adding or removing energy at one frequency can also affect your perception of other frequencies, and it can also change the overall subjective impression in a way that seems to go beyond the actual change.
To put it another way, sometimes the subjective effects of straightforward changes to FR seem more complex than they are. I think this is probably due to masking, but I don't know if that's all it is.
For example, if you have some extra energy at 100, 200 and 400hz and the overall response seems a bit boomy-boxy, and you cut those frequencies, you'll also tend to notice the midrange up to about 2khz sounding clearer and more open. Except it's not, it's the same as it was before, but you can hear it more easily, and so your subjective impression changes.
When you combine this type of effect with the complexity of the 3D dispersion pattern, marginally audible distortion, and room effects, I think it's fair to say that FR (considered at all angles) does tell basically the whole story, but predicting the fine details of the specific subjective result of that FR is very hard to do, because there are very subtle and minor second-order effects happening for every deviation from flat.
The overall picture is easy to see, but when you want to get into whether the midrange is more "silky" or "clear" (for the sake of argument, assume these terms have some objective basis in a hypothetical speaker design scenario) it's beyond me to predict that from looking at measurements.
From that POV I think "final tweaks by ear after a measurement-led design process" seems completely fine.
Yes, this is my own experience as well.
For instance, I can get the general characteristics of the Joseph Audio Perspective2 from the Stereophile measurements. But I personally cannot know from those measurements exactly how much I would like the speaker, and also in this case I wouldn’t have known just how silky smooth and grain-free those speakers were going to sound to me. I’ve seen other speakers that measure somewhat similar at least in frequency response, but did not have the ultra purity of tone that immediately grabbed me with these speakers.
There may be people who can predict with a very high degree of accuracy and confidence precisely how a loudspeaker will sound from the measurements (and those people tend to have lots of experience, correlating measurements to different speaker designs).
But if so, I’m not one of them. So I have to go listen to make my final personal decisions.
Example of speakers designed via measuring and informal listening:
Joseph Audio Speakers.
As Levimax pointed out, especially in relationship to the Andrew Jones discussion, it’s a bit misleading to talk about loudspeaker design designers who don’t use measurements at all. I would think there would be very few of those.
But for those who use both measurements AND some “ designing by ear” I’d suggest Jeff Joseph would be pretty typical.
There’s nothing special about Joseph in this regard. I’m just using Joseph loudspeakers as an example out of convenience, since I own Joseph speakers and I’m familiar with a wide range of reviews and listener impressions of the brand.
To back up: it seems many ASR members don’t want their loudspeakers “ sound like” something. In other words, they don’t want some voiced or coloured presentation, they want the speakers to simply be neutral transducers or conform to measurements that have been correlated to high listener preference scores in blind, listening conditions (and of course those two can overlap).
But a lot of the audiophile world including speaker designers DO want their speakers to “ sound like” something. They have some criteria they are aiming for that is not simply hewing to a measurement standard, but that the loudspeaker “produces a certain type of sound or presentation.” Eg “Sounds more like live music” or some other set of personal preferences as a guiding criteria.
This doesn’t mean that neutrality is completely thrown out the window.
Some people may find that a generally neutral speaker is what gets them to this sound they are seeking. Sometimes a slight departure from neutral, or even a sizeable departure from neutral , may be what the designer ends up with.
I personally want my loudspeakers to “sound like something” and among those characteristics are “natural“ and “sounding more like the real thing”… reproducing what I perceive are some important characteristics I hear in live instruments voices. I have other criteria, but that’s part of it. (as it turns out, I don’t want a loudspeakers straying too far from neutral because a very unbalanced sound does not sound natural to me).
Joseph Audio has a similar approach. This description from their website, captures it:
“Live, unamplified music has unmistakable presence and clarity. Yet, at the same time it also sounds relaxed and warm.”
For me that beautifully captures the “gestalt” that I perceive when I pay attention to live on amplified musical sources.
So right off the bat, an audiophile like me can at least note “This speaker designer seems to be identifying the right things to be going for in terms of what I care about.”
Taking some notes and paraphrasing from an interview with Jeff Joseph, he says he can get good measurements pretty quickly with the speaker, but he uses informal listening to dial-in or ensure he’s getting these qualities:
  • Strives for a purity of tone; he wants to be able to hear the very distinct tone and timbral colours of instruments voices.
  • Wants to have the sensation of listening through the speakers to the original live performance .
  • Wants the listener to be able to hear any part in the mix no matter how tiny or subtle, so if you want to focus attention on a tiny element in the mix or a single instrument, you should be able to clearly perceive those elements.
He says he has certain recordings that he finds useful in getting a handle on the system, evaluating the crossover, etc.
So for instance, he uses a certain piano recordings he’s familiar with to make sure he’s adjusted the fill of the crossover in a way that sounds natural to his ears.
So that’s where it seems the listening and personal preferences and decisions come in.
Did the approach work?
To my ears, Jeff knocked it out of the park. Before I’d even really known the brand, I encountered Joseph speakers at a show and was knocked out by precisely the qualities Joseph seemed to be striving for.
When people are demoing “ good vocal tracks” at audio shows I typically close my eyes to listen and compare them to the sound of real voices - often someone is talking in the room.
It immediately reveals the gap between the mechanical and electronic character of voices coming through a loudspeaker versus reality of sound coming from real human flesh.
But when I did this eyes closed comparison with a vocal track Jeff was playing on his flagship Pearls I was just astonished at how they nailed the timber and tonality of the human voice… there was very little difference between the voices coming from the speakers and some voices occasionally chatting in the same room. The timber and color, and the natural warmth “matched” which to me is very rare.
And then I immediately found a dealer in my hometown to listen to the brand again, and yup… all those qualities were there.
What I perceive from the Joseph speakers is a purity of tone… an effortless relaxed clarity that comes from a completely etch or grain-free presentation. Yet also with some warmth and richness (not thin or anaemic sounding).
The effect on the sound of instruments and voices is like looking through a clear stream from which all sand or silt had been removed revealing all the vivid colours of the rocks and pebbles. In the same way it felt like the distinct variety and beauty of instrumental timbre and tones came through in the way I had rarely heard before. When I played familiar tracks, I was continually surprised as each instrument entered, because each sounded so individual and harmonically beautiful.
Plus, they sound-staged and imaged like bastards, totally disappeared as apparent sound sources, while also sounding rich and punchy from the mid bass down.
I left my first audition incredibly excited and it was after that that I really started researching reviews and other listener impressions.
And over and over the same themes emerged from other listener impressions… essentially citing the same characteristics I just described. Reviewers tended to note the “high level of discernability” where even in dense mixes with overlapping instruments playing in the same register, the distinctiveness of instrumental timbers made it effortless to hear each instrument.
Which is what I experience from my Joseph Perspective2 speakers.
So, the sound profile Joseph was seeking that both he and I associate with live and amplified, music - unmistakable presence and clarity. Yet, at the same time it also sounds relaxed and warm - seems to be exactly what I’m getting out of these loudspeakers.
And it is tremendously rewarding.
Around the same time, I was also auditioning plenty of other loudspeakers, including the Revel Performa F228Be a couple times, and as obviously competent as those speakers were, they did not grab me like Jeff’s speakers.
Would I have preferred the Revels if these speakers were compared at the Harman blind testing facilities? I certainly can’t rule that out.
But if you’re an audiophile like me who’s interested in a range of loudspeakers that go beyond Revel or the loudspeakers for which we have spinoramas etc, then often personal listening sessions is all we’ve got to go on. (the fact that they’re at least some Stereophile measurements is for me helpful but just not definitive).
So while I don’t have scientific level verification for my choice or for the success of the design of these speakers, there’s a heck of a lot of informal listening impressions out there for the Joseph speakers that seemed to align with my own and with Joseph’s personal sonic goals. And it’s made for an extremely satisfying purchase in my experience.
(And none of that is to say that all of the characteristics noted above couldn’t have been arrived at purely through a measurements-only based approach. I’m just throwing out a possible example of design that also incorporates the designer’s subjective preferences, seems to me like it can be pretty successful).
Yes, and to be clear I'm talking about deviations of 2dB or less, or small wiggles in the directivity. So for example if you have two identical speakers and one of them has a single extra dB peak at 500hz, 2khz and 8khz, just looking at graphs we'd have to say "these will sound basically the same".
But, I think if you did fast switching between them, there would be some very slight subjective difference. Once in a while this type of subjective difference amounts to something people find desirable, more often I think it would come off as "merely different". It's hard for me to say just by looking, and maybe it's hard for everyone, otherwise AJ might not care to do ear-tweaking... ;)
Also, as an aside, I am of course not trying to give cover to people who build or defend stuff like the Borrensen travesties, who turn around and say that measurements don't tell the whole story. Those people just can't read a graph and are too embarrassed to admit it, I guess.
I'm more trying to say that frequency response actually explains more preference than people realize, because subjective effects you wouldn't intuitively attribute to frequency response sometimes are still actually because of frequency response. I think this might explain some of the people pondering whether there are alternative measurements that might explain what they're hearing because they don't think it's FR. Sometimes it actually still is FR, but it doesn't feel like it.
I was at CAF is past fall, I forget the brand, but I was in a room where the rep told me that their speakers are probably one of the "most accurate," because it was "tuned" by a "world class musician."
I quickly ran out of the room before he even finished his sentence.
Were they playing Jazz albums played by world-class audio engineers on them? :p
Yes, I generally agree.
In terms of measurements not telling the whole story, I’m not working in the relevant sciences in order to make that determination either way. Somebody like J.J. would be better positioned. I could be wrong, but I seem to remember him suggesting that there’s still work to do in terms of psycho acoustics and human perception, and I’m pretty sure Floyd Toole has said something similar. I wouldn’t be surprised that the science has not ended on this matter.
However, unfortunately as we know the
“ measurements don’t tell us everything about how something sounds” trope has been used as lazy or disingenuous excuses for all manner of pseudoscience and dubious claims and bad measurements. So I don’t hold any particular respect for that trope.
In terms of speaker designers who opine that measurements can’t tell us everything and that they incorporate listening on those grounds I would make a distinction: some of these speaker designers can still manage to create very nice sounding/measuring loudspeaker, while others come up with stuff like those Borresen speakers (I personally could never own speakers that measured just like those ones).
I have very much liked speakers from some designers who espouse that measurements can’t tell you everything and so they include some designing by ear. For instance I’ve made my appreciation of Devore speakers known even though they hardly measure to ASR standards. But I’m not attracted to them because of any philosophy about “ measurements don’t tell you everything” but more about the philosophy and goals for the sound characteristics Devore is seeking in his designs, and how they jive with my own criteria, and on my own impressions that the speakers do hit some of those sweet spots and when I’m looking for.
And these are examples where, as much as I appreciate that the more ASR approach exists, I’m also thankful other approaches exist because they have produced plenty of wonderful listening experiences for me as well.
Going back to the title of the thread... What speakers are KNOWN to be voiced by ear and not using measurements as an important input? I think this is true for Borresen, Chesky and Danny Ritchie but I gladly admit that I don't pay attention to those threads, so I may be mistaken.
I don’t know about Chesky but Borresen employs measurements along with their listening and certainly so does Danny (his constantly showing measurements on his channel for his speaker corrections).
So realistically, it really comes down to discussing speakers that are designed not only with measurements but also via informal (non-blind) listening playing a part.
And if you take a peek just a few posts up, you’ll see I presented an example in Joseph Audio speakers. (and that’s just a specific example from countless other possible examples)
Cheers
Status
