I mean my decent:
Not punishing impedance, linear, high SPL ability, low THD, etc.
I wouldn't even know where to begin on each of these attributes.
There's thousands of speaker brands, and a lot of them are nice, using the rights tools, etc.
How many nice driver companies are around? In the tens? A hundred? A tenth of them proven through time?
And how many of them build nice coaxials?
I believe that many engineers at major speaker companies could design a driver from scratch—based on their experience—that would come very close to the ideal.
There are a great many companies, especially in the PA sector, that manufacture very good coaxial drivers. If you’d like, I’d be happy to name a few.
All other times, on-axis correction ruled.
On-axis neutrality is the most important characteristic of a speaker.
I’d like to ask a couple of questions that seem to have been overlooked in all the back-and-forth here:
Does a loudspeaker with a linear frequency response curve sound the same at every volume level?
Does it sound the same at every listening distance?
Can anyone tell the difference between speakers with a linear on-axis frequency response, one of which uses a horn with a 60 x 40-degree dispersion pattern, versus an omnidirectional speaker, versus a coaxial speaker, versus a D’Appolito design?
Why are people arguing about whether a Neumann or Genelec monitor sounds “better”?
Can you hear a difference between a speaker with a linear on-axis frequency response curve that uses an 18-inch driver for bass, a 10-inch driver for midrange, and a compression driver in a horn for treble, versus a speaker that uses a 6-inch coaxial driver for mid-high frequencies and an 8-inch driver for bass?
Why are there so many different approaches to loudspeaker design—leaving visual aesthetics aside—when it’s now so easy to achieve a flat on-axis frequency response using DSP and solid amplifier technology?
Do these loudspeakers with a linear on-axis frequency response sound the same in every room?
Why are loudspeaker manufacturers still searching for the ideal diaphragm material today?
Personally, I believe that there are only approximations of the ideal loudspeaker, and that a loudspeaker must ALWAYS be suited to the room in which it is placed.
I can now describe my requirements (which are partly interdependent and overlap) for a largely idealized loudspeaker as follows:
Low distortion (harmonic distortion + intermodulation)
Volume stability = very high and undistorted volume possible when needed, without compression, without distortion
Consistent dynamic range across all volume levels = the speaker has excellent dynamic capabilities and reproduces very quiet passages just as cleanly as very high volumes. The soundstage remains consistent across all volume levels.
Very consistent directional characteristics (constant directivity)
Flat frequency response (on- and off-axis, smooth energy balance)
Good transient response = no time lag between drivers, no phase shift, clean impulse response of individual drivers, controlled decay
Low-resonance enclosure
I myself use almost exclusively PA drivers because they can deliver very high sound pressure levels and hardly distort at high hi-fi volumes—so for me, they meet one of the basic requirements for good speaker sound, and I feel quite at home in the SINAD forum.
I’m not arguing here about what’s subjective versus objective, because among the people here—most of whom I consider highly capable—there are at most misunderstandings in how things are phrased, and they’d likely all agree on what sounds good and clean if they were to get together for a blind comparison of different speakers. I don’t think anyone here has anything against measurements or a linear energy-frequency response.
With Sigberg, for example, I think that when it comes to the “finishing touches and final tuning” of his speakers, he mainly considers how a specific speaker performs in a specific room and tries to adapt his speakers to those conditions as best as possible. He also offers a calibration service for his speakers—that’s a truly useful service, which, by the way, is primarily supported by measurements.
And yes, I think it’s possible to design a speaker without listening to it at all. I’ve done it before; it was technically sound and sounded exactly as expected. But I also know pretty exactly what I want to have and achieve.
