@terryforsythe just what is your point? Of course there are objective measurements of high fidelity....perhaps not the highest fidelity, but sufficient in terms of signal integrity and audibility thresholds.
Is there even a speaker available that is transparent in DBT?Transparent in a DBT![]()
What started this thread was another thread in which the term high fidelity was used in an amorphous manner. My point is that the term "high fidelity" is somewhat intangible. To say something is high fidelity is akin to saying something tastes good. It may taste good to me, but maybe not to you. I may say that for a system to be high fidelity, it must provide, from source through the speakers, a flat frequency response from 20 Hz - 20 kHz +/- 0.2 dB with SINAD greater than 115 dB, and driver compression less than 0.1 dB at 102 dB SPL. Do you agree? If not, then what objective measurements qualify an audio system as being high fidelity?@terryforsythe just what is your point? Of course there are objective measurements of high fidelity....perhaps not the highest fidelity, but sufficient in terms of signal integrity and audibility thresholds.
I don’t think so. What would be the reference in such a test? It would be trickyIs there even a speaker available that is transparent in DBT?
The reference would have to be a live performance. But, no speaker I have heard would pass this test.I don’t think so. What would be the reference in such a test? It would be tricky
No, don't think the taste thing correlates at all, as that is more a preference than reference. I might use your frequency response somewhat useful, the SINAD a bit too much, but sounds like pretty good driver performance (which still is far poorer than electronics generally). I dislike "hi-fi" being a marketing thing for some sort of supposed current peak in such....higher and highest are only so meaningful let alone simply "high". We generally have hi fidelity audio reproduction in so many ways I find "audiophiles" splitting hairs on what is or is not "hi-fi" gear or whatever to be as meaningless as if they believe in power cords, special cables, lifters, whatever other audiophool nonsense they may believe in.What started this thread was another thread in which the term high fidelity was used in an amorphous manner. My point is that the term "high fidelity" is somewhat intangible. To say something is high fidelity is akin to saying something tastes good. It may taste good to me, but maybe not to you. I may say that for a system to be high fidelity, it must provide, from source through the speakers, a flat frequency response from 20 Hz - 20 kHz +/- 0.2 dB with SINAD greater than 115 dB, and driver compression less than 0.1 dB at 102 dB SPL. Do you agree? If not, then what objective measurements qualify an audio system as being high fidelity?
Maybe, instead of throwing around the term "high fidelity" like it has a specific meaning upon which everyone agrees, we should be specific as to the objective measurements we are discussing. If we are going to use the term "high fidelity", then there should be objective specifications that define what that term means. Maybe this is the appropriate forum to get that started... But, good luck on getting everyone to agree on the specifications.
Fidelity....
sigh...
You need to be able to do the equivalent of comparing the image on a screen to the image through a window...
My old Quad ESL57's for all their limitations (limited high end and low end extension, narrow dispersion of high frequencies, strictly limited SPL) - they could and can reproduce the human voice in a manner that provides the sort of verisimilitude that I am talking about... No other speaker that I have personally experienced has achieved that specific form of "magic"...
Assuming you have an appropriate recording... of a human voice you are intimately familiar with (eg: family member you interact with regularly) - then you can test that verissimilitude directly.
With the ESL57's sitting in the MLP - the voice was very very "real" - with only spatial cues and room cues giving things away (which is where listening from just outside the listening room, with the door open (obviously) could then provide a truly "spooky" real sounding result.
He's trying to argue anti-science simply for the sake of argument.@terryforsythe just what is your point?
No, who said there was ???Is there even a speaker available that is transparent in DBT?
No its not, at least not today in the realm of electronics and being capable of a "straight wire with gain" performance level.What started this thread was another thread in which the term high fidelity was used in an amorphous manner. My point is that the term "high fidelity" is somewhat intangible.
Yeah the devil's advocate thing I recognize and am often guilty ofHe's trying to argue anti-science simply for the sake of argument.
There is a lot of gear being being sold today that is "voiced" to be not transparent, in 2024 that does exclude it from being considered Hi Fi. It may "sound good" to some, but it's not Hi Fi.
No. I'm arguing that we need to do a better job at following science, not just spewing a bunch of BS and claiming it is science.He's trying to argue anti-science simply for the sake of argument.![]()
Lead the way....No. I'm arguing that we need to do a better job at following science, not just spewing a bunch of BS and claiming it is science.
Good. Now we need to determine what are the objective references to be used for "high fidelity" if we insist on using that term.as that is more a preference than reference.
What do you mean "we" kemo sabe?Good. Now we need to determine what are the objective references to be used for "high fidelity" if we insist on using that term.
Maybe we lay out specifications that must be met for equipment to be classified as being "high fidelity". Maybe we do that for this forum, and it may take hold elsewhere.
TransparentGood. Now we need to determine what are the objective references to be used for "high fidelity" if we insist on using that term.
Let's continue with this:Lead the way....
Well, considering all of your posts in this thread, it seems to be a subject that is of interest to you.What do you mean "we" kemo sabe?
My point was it's more "you" than "we". Time to step it up.Well, considering all of your posts in this thread, it seems to be a subject that is of interest to you.
If you don't want to participate, that's fine.
I agree - but more than not being able to pass the test... I don't believe we actually know precisely what is lacking to be able to pass that test.The reference would have to be a live performance. But, no speaker I have heard would pass this test.
There is something about live music that even the best audio systems (at least the ones I have heard) cannot fully reproduce. So, I guess it could be argued that we do not currently have the technology to build an audio system that truly is high fidelity.
