Holmz
There is probably something in ^here^.…
I think you would be an interesting person to talk to about these things, but for some reason have an adverse reaction to how you present your topics in writing. I do believe I have fundamentally different beliefs than you. For example, I think we would likely disagree about the relationship of mind/brain/body and therefore likely have different readings of imagination, fantasy, subjective (particularly the later as I definitely read that word within a post-structural framework modified via contemporary criticism), which makes this type of communication (forum based) difficult.
"I think that the latter is the overwhelming obstacle in understanding what the question for "disappearing speakers" is. What does it mean to begin with? Some hifi enhthusiasts still don't accept the very fact, that 'stereo' needs *active* imagination, it is not the least any sort of virtual reality. To activate imagination needs good music ... so I'm happy that my speakers 'disappear' every time I listen to a good program of my choice. But I have enough brains (?) to switch any time to listening to the speakers left/right.
So what is reality? In the context of suspending reality?
The first is that the speakers produce sound like they come from a point.may i ask what those two things mean? it sounds very simple if i had an EE degree!
One could use a flat planner speaker, which has a focus at infinity, or some curved speaker which had a focus somewhat behind the speaker.
The minimum phase has no pre-ringing, so I don’t think it is a requirement either.
The toe is probably not as important as away from walls.i'm sure this has been covered ad nauseum over the 39 pages of responses; but for me it seems like just a matter of triangulating the speakers correctly. if i point them in a little and sit at the apex of the triangle formed by the firing of the speakers, the sound stage expands in all directions and i just hear music with no directionality.
Just drive down a road with the window down. If the curbs are square, then you can hear every driveway and also hear how close you are to the curb to an extent.
Blind people are generally not going head first into walls.
Try walking up a driveway while whistling or making clinking sounds with one’s eyes shut - one can generally know when to start reaching out for the wall.
This is really pretty good.
^No^To all: Can you locate your speakers easily or could it be an imagination that it is so?
I think it is highly coupled.I can go a little crazy about that myself because the worst thing I know is to be able to locate the speakers. But whether or how much this speaker localization coupled with possible imagining is, I don't know. Besides, most of the time it's not something I really think about because then I wouldn't be able to enjoy listening to the music. But when it comes to critical listening, well....it gets a little tricky, so to speak.
And getting the early reflections delayed helps a lot (IMO).
