I equalized my hearing so that I don't have to futz around equalizing for speakers and the room.These days with a digital source the speakers are by far a bigger change and need to be equalized with parametric equalization or at least equalization. Are you using a PC for a source?
How come you haven't voted yet?I'll go old school and say the recording
PuFF... PuFF... pass... pass... over to @pseudoid. LoL.Speakers and Rooms may have been better separated... combined together, the results should be interesting.
Thank you.
Where does WAF fit and shouldn't it come way before cable lifters?Where is the "cable lifter" option?
For me:
- Speakers the most difference
- Then the room
- Then DSP
... in that order.
So you think that this:In my experience, A receiver/amp makes the biggest difference. I mean if amps didn't matter, we all would be using amps like the Kinter MA170+.
YesSo you think that this:
Vs this:
Makes more difference than this:
Vs this:
Neither should you buy a $15 speaker..I'm not saying you should spend more on an amp compared to the price of your speakers. I'm saying that you shouldn't spend $15 on an amp instead spend that on a $300 or less amp.
I mean, if speakers didn’t matter, we all would be using a <<insert super cheap crappy speaker model>>.I mean if amps didn't matter, we all would be using amps like the Kinter MA170+.
Far point.Neither should you buy a $15 speaker..
To reflect back at you:
See, I can do that as well
