What Kind of Compact Desktop Headphone Amplifier Would You Want?
Douk Audio
Hi all ASR members,
Douk Audio is planning to design a compact desktop tube headphone amplifier with VU meters. The project is still at a very early concept stage, and we'd really like to hear your genuine thoughts.
Whether it's about appearance, features, or technical details, feel free to speak your mind. Your feedback and suggestions could directly influence the final product.
Here are some specific areas we'd love your input on:
Sound signature: Warm, lush "tube sound", or more transparent and low-distortion?
Features: Do you need preamp outputs (for active speakers)? A gain switch? EQ control?
VU meters: Do you prefer real analog meter movement, or just decorative LED simulation? Should the backlight be adjustable or switchable?
Appearance: Metal, wood, retro, minimalist… what does your ideal desktop tube amp look like?
Feel free to use AI tools to generate images of your dream design and share them in this thread. We're really excited to see your creativity.
Inputs & outputs: What's the bare minimum you need? Is USB necessary? Are balanced outputs (4.4mm / 4-pin XLR) a must-have?
Headphone compatibility: Which matter more to you — high-impedance dynamics, low-impedance high-sensitivity IEMs/headphones, or planars?
Price range: What price range would you expect for such an amplifier?
Also, if you've used any small tube amps on the market and have thoughts on "what could be improved," please let us know.
Thanks in advance for your input. All ideas are welcome!
A headphone amp that can drive anything from IEM's to planars .
When it must have a tube make it so the tube circuit can be bypassed. Make sure the tube section is rolled off a little AND ensure there is a level difference in favor of the tube amp. Don't make one where there is an instant switching with no level difference and no deliberate roll-off as no one would hear a difference.
There MUST be a level difference at least and maybe even a short 'mute'.
Simple tone control would be great.
6.3 + 4.4mm Pentacon.
SE and balanced in.
NO USB nor BT input. Let people buy their own DAC BT/receiver and keep costs down and choose themselves.
Maybe even 2 or 3 switchable inputs (if pre-amp function is present)
Possibly a volume/tone controlled out (pre-amp usage)
Gain switch (low/mid/high) so one has good volpot travel with all headphones.
Real meters that only 'swing to the music' they do not have to have real purpose other than 'swing' (so pre-volume control) and 'auto ranging'.
Price, as low as you can get it but still make a profit.
1 Sound signature: Warm, lush "tube sound", or more transparent and low-distortion?
2 Features: Do you need preamp outputs (for active speakers)? A gain switch? EQ control?
3 VU meters: Do you prefer real analog meter movement, or just decorative LED simulation? Should the backlight be adjustable or switchable?
4 Appearance: Metal, wood, retro, minimalist… what does your ideal desktop tube amp look like?
5 Inputs & outputs: What's the bare minimum you need? Is USB necessary? Are balanced outputs (4.4mm / 4-pin XLR) a must-have?
6 Headphone compatibility: Which matter more to you — high-impedance dynamics, low-impedance high-sensitivity IEMs/headphones, or planars?
All of the possibilities will affect price.
But, referring to my numbers, above.
1 Tubes are for a limited market, and are largely for show, especially for a desktop unit, but why not have a switch that lets you choose between "warm" and "true" sound?
2 Probably no need for pre-outs unless it has little effect on selling price, but these would be useful - if you market anything with 'tubes' in it, you can in any case charge more - "boutique price effect" (so, yes, pre-outs)
3 Nobody needs VU meters unless recording - whether analogue on on-screen they add cost. Most people will be using a "desktop headphone amp" with a PC or phone, and media players already have graphics gimmicks built in that should satisfy the easily distracted folk!
4 Just offer case colour choices. On a (literal) desktop, just keep it small and discreet.
5 You only need USB as a means of connecting to a PC or phone for playback. If you mean USB as an input for memory cards, USB-SSD, etc, then that's not needed - your PC or phone has storage.
6 People buying into tubes are the kind of people that also want boutique headphones that are sometimes difficult to drive (high impedance) - you need wide compatibility, including balanced, or people will moan (esp. on ASR).
