Where I sleep.Lovely, but where's the house?![]()
Yes, still the M126be but with my larger system w Denon X8500H, all outboard hypex amps and two Hypex Rythmik subs. I will take another REW measurement today with the current filters in place and post.By the way @Acerun, is it still about these speakers?
(Source)
If so, could you repost your graph with only the Before line selected?
Might you "dumb down" how one would "let the bass roll off lower and steeper"? I'm using a tilt filter as a baseline +2 to -4, and can add a parametric filter to that if I knew what to try.What I basically suggested is to let the bass roll off lower and steeper. It will hardly increase the boost at 70Hz, while it will make you keep more of the chunk that peaks at 60Hz.
Hope this makes sense.
I don’t know the MultEQ X software, so you’ll have to work out the how yourself or maybe others can chime in. In general the question is why does your corrected bass start to roll off from 150Hz down while what you asked for was a straight sloping line?Might you "dumb down" how one would "let the bass roll off lower and steeper"? I'm using a tilt filter as a baseline +2 to -4, and can add a parametric filter to that if I knew what to try.
Were the subs engaged in the green Before line?Yes, still the M126be but with my larger system w Denon X8500H, all outboard hypex amps and two Hypex Rythmik subs.
Here is the before Audessey Multieq with only the before lineBy the way @Acerun, is it still about these speakers?
(Source)
Yes, with Multieq you measure everything together for your baseline room EQ. Then add filters to taste.Were the subs engaged in the green Before line?
What would you use to make that yellow target? A shelf of some sort?I mean in REW I could quite easily make my target curve do this (yellow dashed line):
When I mention +2 to -4 it is from this target tilt filterI don’t know the MultEQ X software, so you’ll have to work out the how yourself or maybe others can chime in. In general the question is why does your corrected bass start to roll off from 150Hz down while what you asked for was a straight sloping line?
Another thing, where is this -4 you mention in your After line?
Understood. But do you get yourself (as I don't) why your Corrected 20kHz point is at -2 and not -4?When I mention +2 to -4 it is from this target tilt filter
In REW I would use these two controls.What would you use to make that yellow target? A shelf of some sort?
Your subs seem to reach well below 40Hz. So how was this green curve with the subs engaged? Perhaps they were switched on but nothing was output to them?Yes, with Multieq you measure everything together for your baseline room EQ. Then add filters to taste.
I don't and I did notice that. I'm guessing that adding the -4 tilt was the target but with the variation in the actual performance it could only hit -2?Understood. But do you get yourself (as I don't) why your Corrected 20kHz point is at -2 and not -4?
Thanks.Here is the before Audessey Multieq with only the before line
What do you think about this? I adjusted the tilt slightly and put in a 2nd order low shelf at 60, cut at 500 then used a first order high shelf to tame the top end.Thanks.
Here it is with the CEA 2034 graphs overlayed. Scale adjusted and Frequency axis aligned.
This way you can analyse what of your speaker's character remains in your >500Hz in room response, and what of it you'd like to correct and to what extent. I believe I'd leave most of it alone. Maybe I'd knock down some of this 10kHz - 15kHz bump.
Others may see more things to combat though.
