That depends on the domain in which it is used. (And who uses it.)Timbre is a silly and ill defined word.
Very true.Timbre is very complex so might require a very complex definition.
Excellent idea, even if it does little to resolve irrational argument about it.So.. people just use the word in a way that makes sense to them.
So, if Trilok Gurtu is using a frying pan to induce the timbre that I perceive, is the frying pan, by definition now considered a musical instrument, having/inducing timbre?
Ergo, anything making sound can be considered to have /induce timbre.
the speakers sound in no way alters the sound sufficiently that the timbre of instruments and voices becomes unrecognisable. Not even enough to make the recognition more challenging. Which suggests the sound differences between speakers is orders of magnitude less significant than that of instruments, even instruments which are very similar in construction (eg classical acoustic guitar vs steel string acoustic) are trivially distinguishable.
so much of a speakers sound quality comes from its dispersion characteristics - and hence from its interaction with the listening space. Two speakers in room may sound very different, but anechoic (or near field) a lot of that difference will disappear.
This is distinct from the example discussed above of instruments in a concert hall or gym - where the instruments timbre is not dependent on the room/reflections, and can be easily differentiatied through the rooms transfer function. Get close in and the difference betwee instruments does not reduce.
For example we can easily hear the difference between the roar of a lion, and the bleating of a sheep, and identify them as such. Most animals in fact have sufficiently different "vocalisations" that we cen tell species apart. Even to the extent that we can tell what species of bird is singing from the sound of its song.
But most people will not be able to identify a particular lion from other lions (etc) based on how it sounds.
The fundamental frequency of A0 is 27.5Hz. This is correct. That means the first harmonic is 55Hz. Again correct.
But A0 on a concert piano--the string and the soundboard--does not actually produce these frequencies. Only the 3rd harmonic (110Hz) and above are produced by the piano, but your brain makes up the fundamental (27.5Hz) in your head. Again, this phenomenon is called the "Missing Fundamental", as I noted above.
Here is a demonstration video, which you can try playing this on a laptop speaker which likely has no ability to produce sounds below 80Hz. You'll hear the "notes" perfectly fine.
There is no reason for your speaker to reproduce frequencies that does not exist in the recording nor live. That's what the science says. But people believe all kinds of strange things about audio / sound reproduction (see my signature).
Sure. All over things equal, as long as the difference isn't confined to pitch (e.g., Fender Jazz Bass vs a Les Paul) or intensity, the difference is timbralI understand that the word "timbre" refers to the difference in sound between an acoustic guitar and a trumpet. Do you think timbre can also refer to more subtle differences in sound, like the difference between a Gibson and a Taylor? I think so, but if I'm mistaken, then the next paragraph is moot.
I would even go so far as to suggest that how an instruments "loads the room" could be part of its timbral signature.I definitely agree that a speaker's dispersion characteristics impact its sound quality out in the real world.
I would say it sounds better in one vs the other, and be done with it. Casually, one might think of venues as having timbres or being conducive to certain timbres, but unpacking those impressions into useful data would be onerous.I would have said that the timbre is more enjoyable in the concert hall than in the gym. Is this an incorrect usage of the term? If so, what would be the correct term?
Call one lion Luciano and the other Placido and you've got your answer. Your last question falls into the same category with "if Helen Keller fell down in a forest..."Is there a timbral difference in the roar of two different lions? Does that change if one person can tell them apart but another cannot?
I think the key part of the definition is "...that allows us to distinguish between instruments"Do you think timbre can also refer to more subtle differences in sound, like the difference between a Gibson and a Taylor?
I'd be talking about the room/hall/gym acoustics.I would have said that the timbre is more enjoyable in the concert hall than in the gym. Is this an incorrect usage of the term? If so, what would be the correct term?
Why would a speaker do that ?Suppose one speaker system allows us to clearly distinguish between a Gibson and a Taylor, and another does not.
I think that's a bit hyperbolic.I'm glad someone else has spotted this.
It's just part of the definition that it has to do with musical instruments.Then the question is : can you expand this to : anything used to make sound.
Sorry - missed that part of your question. If that were the case I'd consider the speaker that sufficiently damaged the timbre of an instrument to render it unrecognisable to be broken. Not to have timbre.
What about a fuzz box? How do we class or describe those? By the way, limited or impaired is not broken. Insufficient, possibly, broken, not necessarily. Your "broken' speaker might be perfect for something else.Sorry - missed that part of your question. If that were the case I'd consider the speaker that sufficiently damaged the timbre of an instrument to render it unrecognisable to be broken. Not to have timbre.
Pitch is purely perceived, but we don't give up on measuring frequency because of that fact.
"the character or quality of a musical sound or voice as distinct from its pitch and intensity"
- Acoustics, Phonetics. the characteristic quality of a sound, independent of pitch and loudness, from which its source or manner of production can be inferred. Timbre depends on the relative strengths of the components of different frequencies, which are determined by resonance.
- Music. the characteristic quality of sound produced by a particular instrument or voice; tone color.
And you'll note that as I've stated above I'm quite happy to accept the word applying to things other than instruments. I just think it is more commonly applied to muscal situations.I think @antcollinet and @solderdude here are making way too much of the specific wording of a chosen brief definition.
I would say a fuzz box (or any audio processing device / effect) affects timbre, otherwise why use it? Saying it "has" a timbre would be overbroad per standard definitions.What about a fuzz box? How do we class or describe those?
Anybody who has ever played in a band can immediately tell if a Gibson or a Fender is playing.I think the key part of the definition is "...that allows us to distinguish between instruments"
So if you can listen to a guitar and reliably say "That is a gibson" or "that is a Taylor" (without having to A/B compare) then that would count as a Timbral difference IMO.
What this says is what counts as a Timbral difference might be subjective. Because I know I couldn't tell that difference, but an experienced guitarist might be able to.
Similarly - in my discussion above, I can't tell one lion from another from its roar - but a zookeeper might be able to.
EDIT :
