DesertHawk
- Joined
- Apr 14, 2022
- Messages
- 60
- Likes
- 112
- Thread Starter
- #321
I would say this thread has been really helpful.The various definitions of timbre that I can find fall into three groups - music, general, and other scientific definitions.
The whole thing is, as you may expect, a mess. I've become less certain what is actually meant by timbre as I go along.
Standard texts on music give some quite strict definitions of timbre as the property of an (one) instrument, Then a hundred pages later, orchestras, music of different periods, and so on are described in terms of timbre, in clear violation of the author's own definition. The Oxford Concise Dictionary of Music does a similar thing. If you read articles you find that a group of instruments can have timbre, yet the definition of timbre itself says it is the sound quality of 1 (and the copy we have uses the number) instrument. (Some editions apparently shorten the word instrument to inst. as well).
So, I chose to hang onto the idea of timbre as the quality that allows you to recognise the source of a sound, and the quality of sound. Then timbre is assigned to a "complex event" in other definitions. At this point, unless we are going to hang onto a specific science - acoustics, or phonetics (timbre has a different definition set there as well) - we may as well give up on the definition. I'm clearly using a different definition to others here, while some people are switching definitions to make points.
We can always talk about tone quality (another part of definitions in music), or simply the "sound", since we are clearly concerned beyond just recognisability of the sound when it comes to high fidelity, as your post on loudspeaker choice indicates. Timbre in itself is a poor term to us in this context. Could you rewrite your posts in this thread without using the word timbre and make as much sense? - I'd say yes. I think that proposal probably applies to the majority of posts in this thread.
So we can't simply define timbre, and different working definitions arbitrarily allow or deny the answer to your questions. In informal discussion of music, I think we could say yes to both points, but that doesn't help us with measuring the quality specifically in reproduction.
It seems that timbre is just too confusing a word to use formally and give an answer in the sense that @DesertHawk wants, to be able to measure it.
I continue to propose that standard measurements should cover "timbre" as it is a property of sources that have been recorded, but there may be subjective considerations involved as always.
If I'm summarizing what I've gleaned from it.
Essentially, timbre is the "artifacts" that an instrument adds to a note that is played. After reading this, I would say it absolutely can be measured in the sense of we can take a recording of an oboe playing a note and see how faithfully that sound is reproduced.
I never intended to suggest that reproduction equipment "has timbre". I guess you could kind of this that equipment that has a "warm sound" (which is usually distortion though some seem to like like it) as a type of timbre but I, personally, think using the term in that way is just confusing.
When I asked the original question I didn't think it would circle back to this but the conversation has several elements of an argument that's been hashed out on this forum many times. Namely, distortion in instrumentation (e.g. Tubes in a guitar Amp) can be a very good thing. Distortion in reproduction equipment (e.g. Tubes in an Amp) may sound better to some but you are altering what the artist originally recorded.
