I don’t see how that’s the case. That seems like an unnecessary slippery slope argument.
Timbre is the phenomenon by which we can distinguish different sounds, through features like different harmonics, and overtone combinations, attack, and decay, resonance, etc.
“Timbre” is often used in describing musical instruments yes. But it’s a set of real world phenomena that is hardly confined to instruments.
If I have a drumstick and I tap my wooden kitchen table, and then I tap a metal pan, we will be able to differentiate between those sounds. Why? It will be due to largely to the difference in Timbre - differences in harmonics and overtone combinations, attack, and decay, resonance,
It’s the same phenomenon, so why would we use a different word for it?
Likewise, if you compare the sound of a single violin playing a note versus a mass of violins playing the same note (even at the same volume ) how will you tell them apart?
If it’s not by the same qualities known under the term Timbre?
It’s almost like saying that we shouldn’t use the same term “red” to describe both a car painted red and a flower that is red. Because that would be somehow confusing.
Why not? You can understand they are different things and yet identify the phenomenon of “ red colour” also applies to each.
I don’t see how it’s confusing at all If you simply identify what you were talking about.
On one hand, I’m talking about the timber of a single violin note and on the other hand I’m clear about talking about the timber of massed strings.
The various definitions of timbre that I can find fall into three groups - music, general, and other scientific definitions.
The whole thing is, as you may expect, a mess. I've become less certain what is actually meant by timbre as I go along.
Standard texts on music give some quite strict definitions of timbre as the property of an (one) instrument, Then a hundred pages later, orchestras, music of different periods, and so on are described in terms of timbre, in clear violation of the author's own definition. The Oxford Concise Dictionary of Music does a similar thing. If you read articles you find that a group of instruments can have timbre, yet the definition of timbre itself says it is the sound quality of 1 (and the copy we have uses the number) instrument. (Some editions apparently shorten the word instrument to inst. as well).
So, I chose to hang onto the idea of timbre as the quality that allows you to recognise the source of a sound, and the quality of sound. Then timbre is assigned to a "complex event" in other definitions. At this point, unless we are going to hang onto a specific science - acoustics, or phonetics (timbre has a different definition set there as well) - we may as well give up on the definition. I'm clearly using a different definition to others here, while some people are switching definitions to make points.
We can always talk about tone quality (another part of definitions in music), or simply the "sound", since we are clearly concerned beyond just recognisability of the sound when it comes to high fidelity, as your post on loudspeaker choice indicates. Timbre in itself is a poor term to us in this context. Could you rewrite your posts in this thread without using the word timbre and make as much sense? - I'd say yes. I think that proposal probably applies to the majority of posts in this thread.
So we can't simply define timbre, and different working definitions arbitrarily allow or deny the answer to your questions. In informal discussion of music, I think we could say yes to both points, but that doesn't help us with measuring the quality specifically in reproduction.
It seems that timbre is just too confusing a word to use formally and give an answer in the sense that
@DesertHawk wants, to be able to measure it.
I continue to propose that standard measurements should cover "timbre" as it is a property of sources that have been recorded, but there may be subjective considerations involved as always.
