For sake of science, or better to say, as Sir Karl Popper understood it, see:
This is a review, listening tests and detailed measurements of the GRIMM Audio LS1c active DSP speaker and its companion SB1 subwoofer. It was sent to me by the company. Speakers cost US $26,500 in the tested finish (pair). Companion SB1 sub costs US $12,750 for the set, brining the total to...
www.audiosciencereview.com
The subwoofer of that assembly is proving the above and elsewhere formulated 'rule' wrong. The DIY scene has to acknowledge that there was a shift in paradigm. Even Siegfried Linkwitz, the DIY's ol' buddy suggested his Linkwitz transform aka biquad in the 1970s(?). Now you say, huh, not that extreme please. But what is extreme, actually?
In actuality the extreme is where desirable properties are sacrificed for no good reason. The weighing of different properties can be done using the T/S parameters, subsequently performing calculations of expectable diphragm movement, power consumption and all. But it is *not* that the T/S parameters define a reasonable design (aka 'Butterworth, Q=0,7, etc), but the designer does, taking the results of T/S parameter based calculations into critical account.
In short, there is a subtle difference in saying, T/S parameters 'give a good basis' - which is an utterly erroneous take, and saying, T/S parameters allow me to predict properties and I freely pick the ones I need. The calculatory tool of T/S parameters is not a design schema, even if in rancid old books for newbies such is suggested.
Not to say, that the T/S parameters do, explicitely, *not* take into account anything of relevance regarding the actual limitations of a design: excursion limits, gradually approached with more or less distortion, power consumption and dissipation, the human hearing (sic!) and what have you. Hence is is less wise to argue in favour of T/S standard alignments by stating limitations ...
