In audio, you'll have some critics saying that:
- "this class D amp has digital glare"
- "this ESS DAC chip has Sabre glare"
I wonder what is glare, what causes it and would this glare be related to harmonic distortion that causes the treble to lack control or else?
Thank you!
There is no such thing. It is a made up thing by people who don't know how to perform controlled listening tests. If they did that, they would not hear any such thing!
As far as I can tell you cannot make such a statement in general with "scientific" confidence?
I do know how to perform a controlled listening test. And while I have not done this perfectly with instant switching between DACs I have tried to do it best as I could practically with a 10sec or so interval between two DACs and I could certainly hear important differences to me in such tests which I'm confident would also show up with an instant blind ABX test (which I've also performed where practical in other areas). And this between DACs which measure very well.
As for the ESS K2M Q2M etc variants of their DACs. They all seem to show the IMD "hump". As far as I know the level of this hump falls in a range that is below a leniently set treshold based on (imperfect not really scientific) audibility tests, but above a more strict audibility threashold shown by tests.
So as far as I understand it there is no conclusive evidence that says the ESS hump in their mobile range of DAC chips is below audibility?
(see for instance this post: https://www.audiosciencereview.com/...-thresholds-of-amp-and-dac-measurements.5734/ )
Oh you must misunderstand me. I do not argue the invalidity of DBT. I only said that being more familiar with the system / having a lot of time to learn what to listen for would in some circumstances lead to more passed DBT. But this was in a different discussion about a different subject.What you're describing is not really a controlled test. I note that here and elsewhere you argue for the invalidity of DBT. Good luck with that.
Well folks, after spending some time with the Khadas Tone Board I tend to think that "Sabre Glare" is a thing. I know the frequency response is flat, but, anyone seen a peak spectrogram comparison for real music music between ESS and other chips? VW diesels did test clean after all.
And how did you test this?
If the FR is flat so will the spectrogram.
Btw the diesel test results were accurate. The engine management system adopted different settings, I gather when no steering input was detected, ie on a rolling road. Also by recognising the fixed driving cycle of the test. (that could be an urban myth but seems reasonable)
There can be something in impulse response vs. static FR measurements. I want to see peak spectrograms, they should be more objective than a controlled subjective test, shouldn't they? I'd do it myself but no ADC.
Don't have Khadas Board, but do have an ESS9028pro DAC. It never sounded like it had digital glare to me.
Here's the spectrum of the difference of the same track being played over ESS and an R2R DACs (mostly around -110dB):
And the spectrograms, for both (hard to see any differences):
ESS9028pro:
R2R DAC:
Are those two spectrograms I posted not what you're looking for?
My first response is before we go looking for ghosts lets establish if you really saw one, or did you just have the willies put up you by being in a dark basementThere can be something in impulse response vs. static FR measurements. I want to see peak spectrograms, they should be more objective than a controlled subjective test, shouldn't they? I'd do it myself but no ADC.
Have you performed a blind and accurately volume controlled listening comparison and consistently identified the Toneboard against a non ess dac?
They tested clean because VW cheated. The cars' control software switched operating parameters for the tests compared to normal driving.
.The Sabre Glare may all be folklore, but it's interesting why many people agree it exists and describe it in similar terms.
I was of course using a March Audio DAC with an ESS 9038. And most comments on hearing a difference (I'm mum on whether they were correct) have been of the variety that the 8th generation copy was softer and took away sparkle, air and dulled the edge of transients. Hmmmm, doesn't sound like a description of 800 % elevated glare does it? Removing sighted bias makes a heck of a difference..
We just need @Blumlein 88 to run a ESSDAC->ADC->ESSDAC loop.
https://www.audiosciencereview.com/...8th-generation-digital-copy.6827/#post-151814
Any aberrations in the reproduction of the music source would be magnified* with each loop. Assuming the ADC doesn't magically undo the "problem" with each pass.
After a few loops the result (if it exists) should be unbearable.
*stick a mic out there and record your speaker playback, play that back and record it again and play that back. You'll soon understand the "magnification of error" part if you don't already.
I did not but it does sound distinctly different from the DACs that went through my hands. Yeah I know, no need to lecture me.... When have the time I'll do a controlled level-matched experiment but it may take a while before that happens. Here is a discussion that suggests that this "glare" may have to do with the transient response of ESS filters rather than frequencies (see KeithL's post down the 1st page): http://emotivalounge.proboards.com/thread/52163/sabre-dac-glare-frequency-range . The Sabre Glare may all be folklore, but it's interesting why many people agree it exists and describe it in similar terms.
