What is the best AMP/DAC for Sennheiser HD 650
Mr4nT4r
I need the best AMP/DAC for Sennheiser HD 650, i have right now jds labs element ii
budget: $500
Dunring
Florida
I just had a pair of those last week. They sounded amazing on my current stack which is an SMSL SP200 and M300 DAC. You can stay in low gain mode, and same power on either connector so you can use stock cables.
The Magni Heresy and Topping d10s or Khadas tone board also sounded great if the volume wheel location isnt an issue. Also the Drop thx One or JDS Atom and the JDS Atom DAC+ are all good with those and way under budget.
M
Mr4nT4r
so between these
wich one will be better and have a noticeable difference than jds labs element ii
Jimbob54
You're unlikely to notice any real change over the existing unit. What's wrong with the current set up?
M
Mr4nT4r
it's working fine, I just wanted to upgrade mine. since there is no noticeable difference between mine and your suggestion than I'm not going to upgrade
Jimbob54
Sounds sensible. You might want to look into applying eq though to painlessly and reversibly change how the 650 sound to you.
