What is the actual headphone end game?
abdo123
Brussels, Belgium
So I’ve been gaining back interest in this hobby and I honestly have been thinking about what is the actual “end game” for headphones and I haven’t been able to figure it out.
It seems the “closest” thing you can do is to make a mold of your own pinna and attach it to something like the B&K 5128 and see how different headphones would measure on your own ear.
This way the ear canal would not be getting blocked by a microphone as you measure how headphones actually measure on you when you wear them.
The idea sounds so extreme though for someone with median-ish income, has anyone done this before? What do you all think?
Why would you bring a (very expensive) 5128 into the game?
Why not just measure in your own ears?
There is a thread.
In terms of real performance, at least one industry insider has opined that (100 USD? 150?) can get you all the sonic goods, and that spending more money will likely get you worse results.
But makers of costly headphones keep themselves busy by attempting to create a sense of a "next level", and if enough people buy into it, you can bet they'll eventually try to convince you that there's a level beyond that. And so on. That's how they normalize stuff like million-dollar amplifiers: Not all at once, but step by step over a period of time, kind of like the analogy of boiling a frog.
Hi,
there is a short answer and a long answer to this question.
The short answer is: Get a Sennheiser HE-1.
The long answer: It depends on a multitude of variables. First is how your ear interacts with the headphone when you are wearing it, i.e. the HRTF, which is about the idea you are describing. Measuring this would be every difficult for a normal person without the appropriate gear. I don't know how you could get an exact copy of your ears molded, but it's probably fun to watch. And then you would need to find "something like the B&K 5128", but beware: the 5128 costs north of USD 30.000 for a reason. And then you would need to determine how good your own hearing (from the eardrum on) is, i.e. getting an audiogram. And then you would need to work all ot this into a personalized PEQ-setting. And then you would need to find a good headphone to start your search with.
Since this is, well, undoable, the shortcut might be: Find a way to determine your own hearing ability. This can be as easy as using this "Adapt Sound" on a Samsung smartphone or tablet. The hard part is how to translate this into an EQ setting, since Adapt Sound only gives you a graphic representation without values. The workaround: Attach this Samsung thing to a DAC/Amp via USB or use Bluetooth (LDAC) for this.
Then comes the long march: I would start with a headphone that is universally accepted as a reference. In most circumstances, this would be something like the Sennheiser HD 600 or some from the 500 series that undo the 600's shortcomings (560S, 505, 550). If your budget is somewhat larger, then the relatively new HEDD D1 would be a great idea. All of these headphones are reference gear when it comes to neutrality and naturalness, so they give you an idea how "neutral" and "normal" sounds. Tastes and preferences vary, of course.
And then there are a number of other variables to consider. With sound, you might prefer bass or soundstage or detail or "air" and what not. Even more important, since you can't EQ this, is comfort. Two of the Sennheisers I mentioned (560S, 600) have a pretty high clamp force (this can be mitigated easily with the 600, not so easily with the 560S). The 550 and 505 clamp a lot less. But they do have this cover of the yoke that holds the earcup protruding inside the earcup (sic!). All 500 series headphones have that. This can be a problem when you have somewhat larger ears that stand out. I love my 560S, but these sticky outy things can be a pain. Literally.
When your are really starting to get back into headphones, I would suggest finding a good and dependable source of information. I find the Headphone Show on Youtube to be exactly that. They also have a number of buing guides that could be a good start.
There is a thread.
Having a microphone block your ear canal is not ideal if you want to measure a headphone on your ears.
What advantage would a measurement with a totally different ear canal of the mannequin will bring?
You did not actually check out the thread?
You might have found the reference about measuring with blocked ear canal.
There is a reference to Møller's work on headphone measurements.
One interesting paper:
Short answer: there is nothing wrong with blocked ear canal measurement.
many of the younger crowd and contrarians here will never admit that billion-dollar companies can still make great products but I still believe some manufacturers can be trusted for some things, in this case Sony - MDR-Z1R is all anyone will ever need or want.
This way you can achieve the most accurate results I can think of for measuring the frequency response of a headphone on your ear.
I had earplugs molded to fit perfectly into my ear. Obviously something for this purpose and with this sort of money would involve an MRI or lasers. Would probably be very fun for the billionaire class.
I'd use the money for flights/travel, nice hotel to attend a Canjam, test headphones and then buy the winner. Then nice meal, bottle of wine, retire to hotel and and enjoy the headphones.
Hmmmm I might need to save to do that myself....
Or you could use a Smyth A16 Realiser which has in ear mics to measure what your own earspace is doing to color the sound and providing a custom EQ to fix it. My I phone also measures my HRTF with its camera, with the results being usable for its earbuds. Neither cost anywhere near a billion dollars.
The ear canal of the 5128 is not the same as yours so still won't give you accurate correction.
Besides there will still be resonances and certain distortion you can't correct.
Then there is the issue of positioning.
Why not buy a headphone that is known to be 'good' and adjust it to 'taste' ?
Unless you need to use it as an accurate monitor for recording.
In which case you could use calibrated monitors as a reference to get close to that sound.
It is all about references.
It's all made up to upsell to you.
Some headphones are just rubbish, but others are largely dependent on the physicality of your own ears.
I suspect there are many headphones that use the very same drivers from 'Sunny Headphone Driver Factory #34" in Shenzhen that sells at price differences of an order of magnitude depending on having a nicer frame or how many free pairs are sent out to internet reviewers.
Sorry - but you are mostly on your own to try headphones and find what works for you!
ehn. more like get your HRTF measured, get or make a headphone that approaches the average of that and alter to taste with PEQ... That is the endgame for headphones and IEMs.
Since most people can't do the HRTF modelling, you can use this - https://eqbyear.com/ with a low distortion headphone that has little quibbles on your head and then tailor it with some filters
Dt990 with worn pads. M50x and dt770 are top purchases on sweetwater for a reason. graph - 2026-09-22T160359.964.png
Do you (Apples = HIFIENDGAME = many other aliases you had and were banned for) have permission to use the graph data in 'your' comparator ?
Where did you get the 'targets' from they are all modified to your personal taste ?
The M50 and DT770 are not top purchases because of their tonality b.t.w. and certainly not endgame (nor is DT990 regardless of pad condition) nor do they measure well (which is what the OP is looking for, accurate measurements)
What headphone do you think is endgame?
Endgame is a loose term and results in something different for each person depending on several factors.
If that weren't the case everyone would be ending up with a DT990 with completely flattened and worn pads as measured by Oratory in your perception ? ;)
For person A (as in Apples) the DT990 with worn pads = endgame.
For person B a cheap Chinese IEM = endgame.
For person C a Susvara = endgame
For person D a HD600 = endgame
For person E .....
should I go on ? I could probably mention 100+ models.
Just look at https://www.audiosciencereview.com/forum/index.php?threads/what-headphone-s-do-you-own.4285/ and see where people end up with.
I once started this thread to get an idea what popular headphones are but with > 3000 posts often listing more than 1 headphone it would take AI to compile a list of what is popular and even that would be tainted by difference in year of launching and price.
Endgame is what one likes and ends up with without feeling the need to 'upgrade'. The last stage of a search process.
For that reason there is no 'single end game headphone' (well the k€ 90 HE-1 could qualify :D ) but there are many end-game headphones in all price classes.
Sales numbers from certain stores have nothing to do with endgame either but with marketing, visibility (reviews, advertising), availability (stores and online) and margins for dealers.
chair or clothing based subwoofer integration. hardware agnostic surround sound virtualization like Smyth Realizer A16.
