Shielding of signal cables, not only twisting.
Thanks, was pondering that too but do not have any on hand. That closer coil is not moving so the board is going to have to go somewhere else.
Nobody really will care other than me. Mounting externally will have other compromises, so getting out some Flexseal tape and mounting board diagonally. Will likely remove the big terminal block too. The wiring will keep the board from moving much and the outputs are protected. Knew it was going to be a tight fit but want to stop fiddling with this amp and start using it!
