I've been thinking about how much level comes off my turntables, compared with the fixed 2V maximum that comes off my digital sources. So, what I need is a PPM to measure what's coming off the turntables.
I'm taking a Velleman VU meter kit K4306 as it had a good PCB, with all the LEDs nicely laid out, and 1dB between the +5 and -5 indications.
I'm then replacing the half-wave average reading rectifier with a full-wave peak rectifier to DIN PPM specification. The LED indicator doesn't care what it's fed with, it just lights up according to the DC level it's sent. This will be a quasi-peak indicator with 10mS rise time for -1dB, -20dB fall in 1.5 seconds, so pretty much what I'm used to seeing in a PPM. It'll miss any very sharp rises, but I'll accept that, as making a hardware true-peak indicator is in the 'too-hard' category.
I have then found a use for the 'world's cheapest DAC' (mine was actually £3.45 including free shipping from China!!) to provide decoding for the CD player and SBT digital outputs, and I'll arrange the gain of the rectifier such that on the two digital inputs, the +5 LED indicates 0dBFS, whilst on the analogue inputs, 0dB is +8dBu (2V) so the +5 LED indicates +13dBu. As my turntables are set to give 0dBu out on 5cm/sec recorded velocity at 1kHz, I should be able to see if any LPs are recorded particularly hot, up to 13dB above 5cm/sec.
It'll all be fitted into a 2U rack mounting box using an old Behringer SMPS that provides +-15v for the analogue electronics and +5v for the DAC.
It's great to have the time to do stuff like this.
S.
