NOCan the cartridge tolerate the heat involved in soldering?
That's what I thought, too.
Placing an alligator clip between the cartridge and solder joint might help dissipate the heat, but am unsure how effective it might be.Can the cartridge tolerate the heat involved in soldering?
Good idea! Maybe someone could head over to Mikey's Tracking Angle and ask him to try it.Placing an alligator clip between the cartridge and solder joint might help dissipate the heat, but am unsure how effective it might be.
You can solder it, but that requires experience and a good, high-performance soldering station with the right tip.Can the cartridge tolerate the heat involved in soldering?
He's got a sweet new $11,000 Audio-Technica "Speed of Sound" AT-MCD1 Moving Coil Phono Cartridge.
One that costs that much should be fairly durable, right ?![]()
Still hasn't learned about 3H distortion.sophisticated signal analysis software detected 30kHz musical information
So to add this M2 SSD you have to add 2 noisy fans?If you would be interested in the details, please visit my post here...
Not necessarily... They have three wires, so they can be temperature-controlled using a controller.So to add this M2 SSD you have to add 2 noisy fans?
I'd pass.
But what's creating the heat in these cards? My Asus motherboard has 4 M2 slots with none requiring or even allowing for any direct fan cooling?Not necessarily... They have three wires, so they can be temperature-controlled using a controller.
Some NVMe can get quite hot, active controlled heat management is a plus under heavy use (Big transfers, system backups, etc). To avoid thermal throttling, make sense.But what's creating the heat in these cards?
OK if the noise isn't a issue, why not. In my case I avoid fans like the plague whenever possible..Some NVMe can get quite hot, active controlled heat management is a plus under heavy use (Big transfers, system backups, etc). To avoid thermal throttling, make sense.
It's probably designed for high performance not really casual tasks like streaming.
Exactly, all depends of the application, he seems to be focus on keep the NVMe under a certain temp while transfer let's say 50 or 100GB of data, a very low noise fan make sense. Low noise is a must for me on my main workstation and HTPC, but my proxmox server is noisy even with ''low noise" fans... that thing lives in a place where noise is not a problem, otherwise I would throw it thru the window.In my case I avoid fans like the plague whenever possible..
That SATA drives are caved by there plastic enclosures and can not be cooled directly, and plastic is not a very optimum for heat transfer medium.OK if the noise isn't a issue, why not. In my case I avoid fans like the plague whenever possible..
Maybe in that case a larger form factor like SATA might be a better choice though at a loss of speed transfer.
Please visit my post here, and please read the specifications.So to add this M2 SSD you have to add 2 noisy fans?
I'd pass.
Since any noise from them isn't a problem for you I guess it's a non-issue.Please visit my post here, and please read the specifications.
The fans are quiet enough, almost silent in10.3 dB(A); they cannot be heard at all from outside of the PC chassis...![]()
Incorrect, My Crucial MX SSDs and Samsung 870 EVO are cased in aluminum for heat exchange and durability.That SATA drives are caved by there plastic enclosures and can not be cooled directly, and plastic is not a very optimum for heat transfer medium.
Just saying.
I believe that the nice large aluminum heat sink is sufficient enough for cooling M.2 NVMe SSD, but just for sure and for my further "heart-ease" — I mean so that I can completely forget about the heat issue of M.2NVMe SSD — I decided to add two almost-silent fans in push-pull configuration onto the heatsink.It's simply that IME those small form 40mm fans tend to howl and I found it surprising that the nice large aluminum heat sink wouldn't be sufficient.
Man that cartel and nvidia wiped the whole PC enthusiast market in a matter of months. RAM, Storage, GPUs and now mobos.Storage is just toooo crazy expensive today.
