With the TRUTHEAR x Crinacle Zero: Red and the 7Hz x Crinacle Zero:2 you have two in-ear monitors in your budget that are excellent and have also been excellently tested.Budget is 45$
Those are the exact ones I was torn about lol, the zero2 is actually a few bucks cheaper than zero, should I go for it?With the TRUTHEAR x Crinacle Zero: Red and the 7Hz x Crinacle Zero:2 you have two in-ear monitors in your budget that are excellent and have also been excellently tested.
If you have the possibility to apply EQ to them, even better.
EQ Software for Windows, Linux, macOS, iOS/iPadOS and Android
I have both (and a few more).Those are the exact ones I was torn about lol, the zero2 is actually a few bucks cheaper than zero, should I go for it?
How is detail not always a good thing?I have both (and a few more).
The RED is slightly more detailed than the Zero:2, but that doesn't always have to be a good thing.
You should keep in mind that the Zero:2, especially with EQ, is just as good as previous "brand" IEMs for €200 - €300.
To make it easier for you (grin ;o), I can also bring the Moondrop LAN into play, one of my favorite IEMs. For me personally, it sounds perfect even without EQ and I find it very relaxed. By the way, the housing is made entirely of stainless steel, powder-coated and is also smaller than the others. There is also a beryllium-plated dome composite diaphragm with an N52 high-performance neodymium magnetic circuit.
I just ordered another one as a replacement, as the LAN is currently on offer at Amazon DE for €33.99.
By the way, Moondrop has an interesting USB-C FREEDSP cable with micro.
You can also convert the LAN to Bluetooth, like any IEM with a pluggable cable.
The trend is towards third, fourth, fifth...IEM anyway
"Detail" can sometimes mean exaggerated highs, if you are someone that experiences listening fatigue then "more detail" may not be good for you.How is detail not always a good thing?
Is it the case in the zero red?"Detail" can sometimes mean exaggerated highs, if you are someone that experiences listening fatigue then "more detail" may not be good for you.
Mostly comp, so footsteps mattercompetitive gaming or casual btw?
just thinking about this some more, you've shortlisted great options alreadyMostly comp, so footsteps matter
Yeah but i dont really know which one to get, actually its for my friend so i want something hell like. I already told him to get the zero red and he orderd it but we decided to cancel once we saw there’s a version 2. I told him not to rush until i ask around and see what peoplee thinkjust thinking about this some more, you've shortlisted great options already
maybe you could use EQ (example), then tweak it and make a config for gaming. you could boost the frequencies for footsteps this way.
yeah fair enough. i don't think they'll be disappointed with whatever they getYeah but i dont really know which one to get, actually its for my friend so i want something hell like. I already told him to get the zero red and he orderd it but we decided to cancel once we saw there’s a version 2. I told him not to rush until i ask around and see what peoplee think
I listened to all three IEMs again and would definitely recommend the TRUTHEAR x Crinacle Zero:Red for your application. For me it is simply a little clearer/more transparent and everything is a little easier to locate, regardless of EQ.Yeah but i dont really know which one to get, actually its for my friend so i want something hell like. I already told him to get the zero red and he orderd it but we decided to cancel once we saw there’s a version 2. I told him not to rush until i ask around and see what peoplee think
I don't mind the cable of cabled IEMs when I game, as long as I can disconnect their cable easily when needed. I have been thinking of trying the Moondrop Little White though. It should have enough battery for longer sessions, and should be rechargable whilst playing if need be. Currently with my wired IEMs, if I need to move away from the PC quickly, I tend to just disconnect the cable and leave the IEM in my ear and the connector in my pocket - it is faster than removing and inserting the IEM into my ears again.I don't want wires hanging especially when playing. Maybe try JBL Quantum TWS, made specifically for gaming, with a dongle for non BT zero lag connection, comfortable, long lasting battery. JBL is quite Harman compliant usually but haven't seen these specifically measured. I like them, they sound similar with other JBL TWSs (live pro 2, tune flex etc).
Zero (Red) and Zero (Blue) are NOT the first generation compared to Zero:2, they are different products from different company. They are more expensive for a reason - they seem to have a better build quality, in particular SIGNIFICANTLY better cable (cable is junk on Zero:2). I've never tried the red variety but Zero Blue after EQ sounds better to me compared to Zero:2 (with and without EQ) - it sounds spacious, kind of like open headphones. However, Zero Red and Blue both have very thick nozzles and in general are bulkier, so may be a poor fit for small ears. And without EQ Zero:2 sounds better than Zero Blue (not sure about Red). Oh, one more thing - these Red and Blue zeroes a VERY sensitive to the impedance of the source, they may sound bass heavy plugged directly into computer headphone jack.Those are the exact ones I was torn about lol, the zero2 is actually a few bucks cheaper than zero, should I go for it?
