Kevbaz
Dan Clark Audio AEON closed X please,
Cheers
Kev
Cheers
Kev
It's not the size that changes the sound but the way you are able to insert the IEM in the ear with a different size tip. (good seal vs bad seal, deeper vs less deep). So this is a very personal thing. No 2 persons will be able to fit an IEM in 100% the exact same way.- I listen with S sized tips, M and L sized ones will sound different to varying degrees (will have to order tips in those sizes for Amir if he decides to test them)
Bore length changes with tip size though, even if all other factors somehow remain the sameIt's not the size that changes the sound but the way you are able to insert the IEM in the ear with a different size tip. (good seal vs bad seal, deeper vs less deep). So this is a very personal thing. No 2 persons will be able to fit an IEM in 100% the exact same way.
What matters is the tip size used during measurements. The insertion depth influences the measurements and with the right tip-size it is possible to create consistent insertion depth into the fixture. This creates consistency between measurements on different model IEMs.
I think that depends on the brand of the tips. I don't think length changes with size for all brands.Bore length changes with tip size though, even if all other factors somehow remain the same
I think this is here. I hope to get to it "soon."Amir can you please measure the LCD XC pls?
I think this one is here as well.HIFIMAN 400SE
See the Aeon RT closed. Pretty much the same thing acoustically.Dan Clark Audio AEON closed X please,
Cheers
Kev
That's what you assume. Let's have Amir measure one to confirm it.See the Aeon RT closed. Pretty much the same thing acoustically.
There’s a whole thread detailing the Aeon X vs the Aeon RTThat's what you assume. Let's have Amir measure one to confirm it.
With measurements?There’s a whole thread detailing the Aeon X vs the Aeon RT
Here: https://www.audiosciencereview.com/forum/index.php?threads/drop-dan-clark-audio-aeon-closed-x.26711/With measurements?
I'll do a search.
Oppo PM3
Any eta on your review for the LCD-XC? Just received my pair and am looking forward to your Roon EQ settings for the XC 2021.No, they sent me the new LCD-XC.
