watchnerd
Measurements of your gear, are you talking about your headphones? You can't really get them as accurate as a set of good speakers, for the reasons I've described, even when the headphones have been measured.
Maybe I'm playing fast & loose with my use of the words "most reliable reference standard".....but probably not thinking about it. The gold standard for speakers is what we know from this site - anechoically flat speakers (not to mention the Floyd / Toole work). That is a far more reliable standard than a set of headphones that almost certainly have random peaks and dips which you can't know about (even if they've been measured)....for the HRTF and headphone transfer function reasons I've already described which varies from person to person. I think the only way to get rid of a lot of those issues is using the Smyth Realizer system which is prohibitively expensive. That doesn't mean you can't enjoy headphones, but they're certainly not more accurate than a good set of speakers. Yes, they can be more accurate in the bass (like I described earlier), but not in the treble.
You can't assume that everybody who listens to your music will be using Toole-approved designs.
And even if they are, there are enough differences between speakers with good spins to affect all sorts of elements of a mix.
The Circle of Confusion is real.
