A bit of intro:
- I like a bit brighter sound and I rarely have issues with sybylance. I hear up to 15KHz.
- I like rock, progressive, new wave, synthpop, electronic, not into classical with some exceptions.
- I don't listem much to headphones, I prefer speakers.
- I rarely (almost never) stay longer doing nothing else than crytical listening.
- I EQ whenever possible using presets in Wavelet app.
- I (thought) I cannot use IEMS. I just found a conterexample but everything else I tried just felt/lost seal after less than one minute.
- I have a very small defect of the ear lobe at the top of it, nothing affecting sound but because of that 1-2mm round skin missing I am picky with the comfort, headphones need to fit for me or no game.
- Since Bluetooth works well I cannot stand wires anymore. This really matters to me.
So here my dirty collection is, in no particular order:
- Sennheiser HD600, probably about 20 years old. I always tried to love them, never managed to score a longer than 30minutes listening session with them, no ideea why. They sound good with or without EQ, they stay well on my head and ears, I have no issues with them but I just don't feel like grabbing them and put them on my head and listen. Wires don't help.
- Drop HE4xx, very good comfort, very good sound, I'd use them if not for the wires that Hifiman Deva don't require.
- Hifiman Deva BT, love them, sound, comfort, no wires. I use them most of all at home. EQ in Wavelet for these is broken, it heavily distorts regardless of volume. They sound very good without EQ so no issue here.
- AKG K371BT, not bad materials but the headband is atrociosly stupid, no good fit for me, loose on the bottom part of the ears, bad seal, I should have loved these but they resisted. They have an issue with the wires from new, one channel doest't work, don't remember if with all cables and if sometimes works based on luck and how good the plug fits. Bad QC on their part, not a dealbreaker for me since I don't like wires anymore. For how Harman compliant they seem to be, I wonder why Wavelet proposes a rather significant EQ in the bass region. However they sound good with that EQ. I wouldn't use them without EQ.
- AKG K712 Pro, no way they work for me (headband). Nothing very special about sound also. Don't care to EQ them.
- AKGK702, almost the same as K712, not used at all, not my type expecially because of headband. Don't care to EQ them.
- Audio-Technica ATH-AD900. There's something about these. Their wings on the band work remarcably good for me but the original pads were not comfortable, the sound was to my taste with no EQ, bass shy of course but ok. I ordered a pair of cushions from Aliexpress, deep and from leatherette with tiny holes. To my surprise this transformed these headphones into a gem. Perfect fit, light as a feather, great sound stage, I felt in love with them. The metalic grill looks gorgeos from close distance. The cable is bad (microphonic, thick, not flexyble enough, not removable) and since I have found a good open wireless alternative (Hifiman Deva), my Audio-Technica idles on a glass head in another room. Still a great surprise, a frog turned into a price with some generic cushions totally different from the originals.
- Sony WH1000XM3, great phone with EQ. Without EQ no way for me. Everything about them is good: build, looks, sound, battery life, noise cancelling, comfort (perfect for me). They can get hot and could use a PEQ in their app but that's just nitpicking. They are my favourites when not at home and I frankly don't understand why this was not my last pair of headphones.
- Philips SHP-9500, loved them, now moved on but they have something special (instead of missing bass). I even bought a specially built for them BT adapter that fit like that on Deva but it's bad quality.
- Philips Fidelio X2HD, build like a tank, good sound to my years, comfortable, if not for the wires and probably a bit too heavy these would be on my head more often. Because of good wireless alternative they just hang here.
- Sennheiser HD1 (aka Momentum 2 over ear). They sound good with EQ, used them untill I got Sony WH1000XM3. Their headband is not comfortable at all, hard and presses just in a narrow region of the head. I will never keep part of these because of the Pink Floyd design/theme, totally love it.
- Sennheiser Momentum 2 on ear. They sound good with EQ, I used them a lot before getting Momentum 2 over the ear (HD1) and Sony WH1000XM3. Their headband is as bad as HD1's.
- JBL Tune 710BT, very good sound unequalised, low build quality, hurts my ear after few minutes, I'd use them if they had larger pads for better comfort. Their sound tempt me to try a higher tier JBL, Club 950 or One perhaps.
- NAD VISO HP 70. Looks gorgeous, good quality built and materials but not comfortable for me, a dark even with EQ for my taste or it may be because I feel claustrophobic with them on, something about the clamp force, pads make me feel like I have no freedom to move, too tight fit+a darker signature? I hoped to like them, like I did with AKG K371bt, having a top place for Harman compliace, no luck. They are in their box, used them like 2 hours, I will part ways with them.
- AKG K412P, some sort of Koss Porta Pro, beaten them to death outdoors at their time. Open, small on the ear, light, not the very best comfort but quite ok. Used to love everything about them except a bit of disconfort for longer sessions. At the time I had not great expectation for bass from so small open HP. Long time retired, since arround.
- Sennheiser HD238, used them a lot outdoors, better than AKG K412P they replaced on my head on the move.
- JVC HA-ET45T, in ear. It was my last attempt to find a good fitting in ear. I bought them for the price, as a test, hoping that they stay better because they have a thing to hang on the ear like glasses so the weight won't make them fall/move. They work to some extent. Sound is passable, no EQ for them in Wavelet but they don't scream for one. They do their job on rare (way too rare) occasions when I work out. Short of a miracle, in-ears are not for me and not because of the sound. Perhaps a custom shape would work but I don't feel tempted to go there.
