I was reading the specs for the Technics Network CD Receiver SA-C600 and in the specs it is rated from 4 Ohms to 16 Ohms speakers. 16 Ohms is a bit before my time and I am wondering what happens if this rating is exceeded.
Even more important from my point of view is the fact that we have an interaction of the output LC resonant circuit of most cheap class D amplifiers with the complex impedance of the speaker. Pure resistor load 4 - 16 ohm does not tell the whole story, it only speaks about damping factor of the LC Q, which is usually tuned to make flat response with 4 ohm resistor. Higher resistance leads to FR peaking. Complex impedance load may transfer the peak as low as to 10 kHz. Unfortunately, this remains untested here.PMA's comment is worth noting. For some class D amps like the old TriPath class D, the higher impedance will cause a peak in the treble and low ultrasonic. With enough of an increase things might go awry.
Yes. As you said with Hypex or Purifi we don't need to worry. I think the Tact amps I have which are Tripath based, they were optimized for 6 ohms. Stereophile does show measurements of FR with 2,4 and 8 ohms along with their simulated load. ICE Power amps don't seem horribly misbehaved this way. Though not as well behaved as Hypex or Purifi.Even more important from my point of view is the fact that we have an interaction of the output LC resonant circuit of most cheap class D amplifiers with the complex impedance of the speaker. Pure resistor load 4 - 16 ohm does not tell the whole story, it only speaks about damping factor of the LC Q, which is usually tuned to make flat response with 4 ohm resistor. Higher resistance leads to FR peaking. Complex impedance load may transfer the peak as low as to 10 kHz. Unfortunately, this remains untested here.
What happens if this is the case and >16 Ohms speakers are used?A lot if it is a usual class D Toy amplifier with output LC and no FB correction of its impedance.
you get more deviation in the FR > 10KHzWhat happens if this is the case and >16 Ohms speakers are used?
Nonsense.Class D + High impedance loudspeaker...
And that's playin' Little Girl with Guitar music!Play something like Fanfare for the Common Man and it's game over, ol' son.
ahem.
back in the good ol', bad ol' days of output transformers -- and with apologies @atmasphere and others who espoused other approaches-- there were several companies who went a slightly different route. Philips was probably the better known, but Stephens Trusonic did it, too.
source: http://hifilit.com/Stephens/Stephens.htm
I have a single 106AX... but, for better worse, not one of the 500 ohm variants.![]()
Nonsense.
If the class D is properly designed then a high impedance load won't be any problem at all.
I was just joshing around -- in fact, riffing off of the post I quoted.Nonsense.
Some tube power amps though may die, AFAIK due to overvoltage in the output transformer.Think of this: What happens to an amp when you have no speakers connected at all? That is equivalent to having really, really high impedance speakers connected, right? And nothing at all bad happens to the amp. The voltages are right there on the terminals but no current flows.
Wonder how many people got electrocuted? 20 watts into to 500 ohms takes 100V RMS.Class D + High impedance loudspeaker...
ahem.
Your down to 15 watts, thats the only problem.I was reading the specs for the Technics Network CD Receiver SA-C600 and in the specs it is rated from 4 Ohms to 16 Ohms speakers. 16 Ohms is a bit before my time and I am wondering what happens if this rating is exceeded.
Actually the problem in a tube amp might be arcing if the load is removed while the amp is playing. With no load otherwise its a different story, as the tubes will see a very high load impedance as well (so will not be able to make much power) since the transformer always reflects the load in either direction. I've never seen an amp damaged by no load, although I did hear of one design that could oscillate with no load. But that's more a design flaw than anything else.Some tube power amps though may die, AFAIK due to overvoltage in the output transformer.
