I would like to see some Quad classics measured, a rebuilt 303 or 405-2 for example.
After reading the review of the Denon AVR-X3500H and seeing how the DAC measurements at 1 volt are pretty good, I’d love to see how some of the Parasound Halo amps perform. They all have 1 volt input sensitivity, which should make them a good match for taking some channels off the AVR. Specifically, I’d be interested in the:
Parasound Halo A23+ 2 channel amp
Parasound Halo A52+ 5 channel amp
Parasound Halo HINT 6 2 channel integrated amp with HT bypass
For class A/AB they are not insanely expensive and are supposed to sound great. The idea being buy a inexpensive ish AVR like the Dennon X3500H whenever the video tech requires an upgrade and keep the Parasound long term.
I've used several (less expensive) Parasounds and never had any hum issues.I had a Parasound A51 and a Jc1. despite the massive shield on the transformers, they both had considerable mains hum on mine. tons of power though.
Based on some of the measurements taken on other sites https://www.soundstagenetwork.com/i...ac&catid=97:amplifier-measurements&Itemid=154Dear Amir!
If possible...would love to see your review of any product from Gryphon Audio.
https://gryphon-audio.dk/
That´s some really expensive stuff in my country...with glorious reviews anywhere...
Also...they look great too...
Will The Mighty Gryphon survive a ASR review?
That will be cool!
View attachment 53818View attachment 53819View attachment 53820View attachment 53821View attachment 53822
Good choice.+50W / channel tube power amps. el34 or kt66/88
If I missed it, please point me in the right direction. What is the best way to get a clean USB signal from a pc. Is there a guide for those motherboard/pci/sound cards that do this well?
I believe my USB out is good, but I can’t measure it as far as I know. It’s silent now. I use a PCI card just for USB. I paid $400, can it be done for $150?
I grew up using the crappy line level outs of sound cards. Now, USB has been noisier than I knew it could be.
Is OCXO beneficial on the pc side or the dac side? Never both, right? Which clock is better? OCXO, TCXO, Femto, how many picoseconds does it take ?
are there DACs that can take whatever usb you feed it and clean it up reliably? This is one instance where noise is easily identified, costly to eliminate.
@Kal Rubinson Do you still have the A52+? I’d be willing to pay for shipping to get it tested by Amir provided it isn‘t prohibitively expensive to do that.I've used several (less expensive) Parasounds and never had any hum issues.
A31
A52+
A21+
P7
and probably a couple of others.
1. I do not still have it. OTOH, I am looking for a new 5+ channel amp as my trusty Bryston 9B has blown a channel (again) and I have decided to move on from it. The A52+ is a possibility.@Kal Rubinson Do you still have the A52+? I’d be willing to pay for shipping to get it tested by Amir provided it isn‘t prohibitively expensive to do that.
