What electronic audio products you want tested most
What electronics audio product you like to see tested more
  • Power and Integrated Amplifiers
    Votes: 688 54.7%
  • Headphone Amplifiers
    Votes: 199 15.8%
  • Home Theater AVRs
    Votes: 325 25.8%
  • Home Theater Processors
    Votes: 210 16.7%
  • DACs
    Votes: 381 30.3%
  • Streamers
    Votes: 290 23.1%
  • Combo DAC and Headphone Amplifiers
    Votes: 252 20.0%
  • Phono preamp
    Votes: 119 9.5%
  • DSP (digital signal processors)
    Votes: 420 33.4%
  • Vintage audio products
    Votes: 289 23.0%
Would like to see a new set of headphones (reasonably priced) reviewed.
MEZE AUDIO 105 AER | Wired Over-The-Ear Lightweight Audiophile Open-Back Headphones​
Regards,
Greg
Amir. Can't you try this for fun? This eternal rant about the cozy tube distortion sound you know. At least that way we know if the program delivers the distortion it claims. After that, people can test for themselves and see how cozy it is (in the long run) with a lot of distortion. :oops: ;)
What is PKHarmonic?
PKHarmonic is a VST plugin for Windows, designed to add second and all the way up to the 8th harmonic by simulating a device non-linearity. A simple slider control for each harmonic lets you fine tune the level from -200dB to +10dB in real time, as you listen. This makes it possible to configure your playback software to generate similar levels of distortions to simulate a tube preamp or an amp, or another device with some level of non-linearity.
What is PKHarmonic?
No need for Amir's AP to test this. Just use digital loopback to feed into REW or Multitone or other measurement software and use your favorite player with this VST enabled to see the result. Here are some examples:
H2 set to -60dB at 0dBFS 1Khz, using Foobar2k to play:
REW measurement of a 0dBFS 1Khz sine shows H2 at -60dB:
Same PKHarmonic setting, but now playing a two-tone DIN250/8k test signal at -1dBFS:
Let's add a higher level harmonic, H3 at -99.8dB:
Let's see if this does the right thing by measuring in REW. H2=-60dB, H3=-99.8dB, as expected:
And add higher-level harmonics:
Result: all harmonics measure exactly as set in PKHarmonic:
And with DIN250/8k signal:
Any other tests that you'd like to see?
Seems like DACs and Headphone amps are a settled issue. However, power amps still come in many different levels of quality. The great underperformers are the AVRs.
It is perfectly sufficient for me with the tests you performed. :)
It was interesting.Thanks for testing and showing the results.:)
Sorry, I missed. Are you the one who created the PKHarmonic VST Plugin? Well done I must say. :D
For some time now, I have been running @pkane's PKHarmonic VST which has the ability to add various amounts of harmonic distortion.
I’d say look at the category and ask yourself if one would have multiple good choices at different price points to build a system based on available reviews.
We need another chinese DAC review or Purify/Hypex power amp review like we need a hole in our head. Any Topping product is likely going to be at least good enough. I think they have earned an assumed ride for awhile.
Home theater devices are more problematic, very common, and not as often reviewed. I think this is where some efforts would pay dividends.
Actually, I don't think we have seen measurements for a Purifi 1ET6525SA based amp yet. I'd be keen to see these, especially the power sweeps at different frequencies (as these are not on the datasheet).
I'd like to see more AVRs etc being measured too.
Its going to be in the upper end of the scale with the only blemish being mediocre distortion above 7khz and 10w.
Speaking of which, I used to be able to go to the "Reviews" tab and select whatever product I wanted to see; I don't see that selection anymore. Is it somewhere else now or am I totally missing it?
No, it is not you. It broke when we upgraded our underlying server APIs. Developer is working on fixing it....
Oooof! 40 pages! I must have gone thru every page in the past.
Of the 10 selectable hardware categories; not one is for small-form-factor ADCs (e.g.: E1DA Cosmos ADCiso).
I have a some errant analog audio output devices (RCA/XLR) around the house, that sure can use an ADC for Volume/EQ/etc.
There must not be that much demand for such *stand-alone, *reasonably priced, and *quality ADCs.:(
Yet, a torrent of DACs have saturated the audio market..., to the benefit of us all.:)
Reactions: EJ3
Here is what I would like to see tested...
There seems to be this trend to put tubes in *everything*. Lots of Chinese makers are doing this. DAC+tubes, Preamps+tubes, phono stages, etc.
I am curious where their measurements fall WRT to comparable solid state devices. Many say tubes come with more noise and distortion over solid state but I wonder by how much?
Any chance you can test the Topping D70 Octo. I am curious how it compares to the Pro Sabre.
The only DAC that I'm curious about is DX5 II, but I'm sure Topping will send it to Amir anyway..
