Did you hear them in person? You can't trust what you hear over the Internet, played back on your system.There must be a subwoofer
this driver does not give real deep bass, it need a sub for that. Xmax is also quiet limited.
it's probally aperiodic ported, with holes on the back reducing the peak and making it go a bit lower. This is a trick that works, but is hard to simulate and not precise or high fidelity at all. But that trick is often used to make high qts drivers work in small enclosure without one note bass.If you listen the recording, it has nice bass that goes down to 50hz. Is it due to passive equalizer shown by @voodooless or a hidden subwoofer?
The volume of the enclosure I guess is 15 liters. This gives a resonance of 110hz with Qts of nearly 2.
No, it's 20 liters closed. The rest is done by the high-pass cap.it's probally aperiodic ported
