TrippRyder
- Joined
- Dec 21, 2022
- Messages
- 36
- Likes
- 18
I never mentioned Class D amps.Negative feedback is or was not the problem with class D amps, it's the disharmonic noise that it generated in older models. The IC's were noisy, the smps was not as advanced as now used and so added noise, and disharmonic noise is very disturbing. It needs to be below 100dB to be not disturbing for me in a hifi situation and untill the birth of the first NCore, it was not that low. W
ith a class A amp, and less degree a class AB amp, the noise can be much higher as the strongest noise that masks the rest is harmonic, and low harmonic. And those enchange the sound and create the "warmth" and "life" (actually low harmonic distortion), that TrippRyder misses in class D amps and claims comes from negative feedback.
Negative feedback can reduce dynamics of music by smearing it, but the ammounts fof negative feedback that is needed for that is far beyond what is typically used in amps. It's not that that takes away what you want. It's the lack of harmonic distortion that disturbs you. I also prefer harmonic distortion btw, but real clean class D amps like the NCore or Purifi amps can also appeal to me. And i prefer very low disharmonic distortion in my "harmonic distortion amps", so this Nobosound is crap to me (to return to the original topic). And yes, i have one of the older models.
Ever heard a Class A tube amp\preamp that uses a cathode follower in the circuit? It absolutely squashes the sound, and it is essentially 100% nfb. Not Class D, not A\B, a Class A Triode tube. No thanks, but hey, it measures great!
So without seeing test results or hearing the E6 for yourself, you claim it to be "crap" because you guess it has high disharmonic distortion?
This post keeps getting better and better! So much slander and shit talking about a preamp that most of you havent heard, have very little knowledge of, and are biased against because of its cost and origin.
Did any of you notice the writing on the circuit board "Rev. 5.0"? Hmm, maybe theyve done some tweaking before releasing the product.......
It MAY measure terribly. Time will tell. I just find it ridiculous that on a page called Audio Science Review there are so many bigoted opinions.
