GabrielPhoto
- Joined
- Jul 14, 2020
- Messages
- 435
- Likes
- 232
uno momento...still watchingSummary or do we have to watch it?
and important.He is down to -120dB and he is calling any change as huge.
Subtle point.Can somebody detail why the 50Hz could be lower with the power conditioner?
The conditioner does absolutely nothing to 50 Hz. If it did, it would be reducing the power available to run the equipment!!!Can somebody detail why the 50Hz could be lower with the power conditioner?
Unfortunately you are bound by mathematics. Let's say you have 44.1 kHz sampling. If you tell the FFT to use 44100 samples, it naturally takes it a full second of audio to get one snapshot. He is using 128 k which means multiple seconds between updates. I use 32K in my dashboard as a balance between having fast enough updates and reasonable reduction of noise floor. When I want to do demos like he does, I play with bandwidth and FFT rates to find a combination that conveys the information easier and better than what he is doing.@amirm is your FFT metering gear fast like real time or does it need settling time and refreshing at a slow rate too?
Cool. That's why you are the boss around here.The conditioner does absolutely nothing to 50 Hz. If it did, it would be reducing the power available to run the equipment!!!
What he is seeing is a common mains leakage due to analyzer being hooked up to the speaker output of the amplifier. An amplifier is normally driving a speaker which has no mains reference. Whereas the analyzer has some (no matter how isolated it is). That it changed with the power conditioner means that the leakage paths/currents changed resulting in that lower amount. It can be purely accidental and go the other way.
You can tell a lot of those noise spikes exist before he powers on the Bryston amp. All of those are instrumentation noise/errors that he is seeing, not what the Byrston is outputting.
Got it... Thank you.Unfortunately you are bound by mathematics. Let's say you have 44.1 kHz sampling. If you tell the FFT to use 44100 samples, it naturally takes it a full second of audio to get one snapshot. He is using 128 k which means multiple seconds between updates. I use 32K in my dashboard as a balance between having fast enough updates and reasonable reduction of noise floor. When I want to do demos like he does, I play with bandwidth and FFT rates to find a combination that conveys the information easier and better than what he is doing.
