Sokel
- Joined
- Sep 8, 2021
- Messages
- 10,656
- Likes
- 11,548
You have to consider levels and the distortion structure looking at it.How to do a null test in REW ... I am embarrassed to say that I do not know how. I know how to do it in Acourate (which is what I normally use). In REW I thought you do the inversion with Trace-Arithmetic 1/A, and then the convolution with Trace-Arithmetic A*B. I tried it with some spare measurements that I have. But for some reason it gives me a different result to Acourate. In Acourate, it nulls out. In REW, it doesn't. I'll have to ask a REW expert for help on this, very sorry.
In any case, the cable connection you made is fine.
The THD+N measurements are not great. We don't know if it's the output or the input since it was measured with a loopback cable, but it should still be below audible limits. I am starting to think that we won't be able to get to the bottom of why you are hearing a difference with this testing. You might have to send the device to Amir for testing.
I guess that if the mic input could stand higher levels (the missing 15-20dB or so) the limiting factor would only be noise,so a -90dB THD+N seems perfectly plausible.
We also have to consider impedance mismatching I suspect, interface's input are usually low.
