what can I do?
musica
I have a subwoofer without a remote control .
i want to control the volume of the sub via the sebaj 10h, how can i do this?
staticV3
You plug your DAC into the A10h's RCA input, and your subwoofer into the A10h's RCA Pre-output. When you turn the volume knob, the volume of the sub will change.
M
musica
can I not connect the sabaj a10h to the pre out of my amplifier?
Chrispy
PNW
Looks like that's what he meant, it's your only choice, don't see a dedicated sub pre-out....just need to connect to both L/R inputs on the sub so it can sum to mono....
ps now that I read your post again, what do you mean by "amp" if not the Sabaj?
M
musica
Please list all your audio components so that we can give you better answers.
denon pma 700ea amplifier with pre-out, 2 speakers, and 1 active sub connected to the denon pre-out all sound sources connected to the denon.
i want to control the volume of the sub via sabej a10h how do i do it?
Chrispy
PNW
So you just use the integrated amp as a power amp? If you split the pre-outs on the Sabaj to both sub and amp/speakers the volume control would be from the Sabaj.
M
musica
If all your sources are connected to the Denon, then what is the Sabaj doing?
now nothing, but I want to connect it between the denon's pre-out and the sub's input to control only the sub's volume
Chrispy
PNW
Maybe bigger question is why do you want to control the volume of the sub separately from your speakers then?
M
musica
Denon PMA-700AE Pre Out -> Sabaj A10h RCA input -> Sabaj A10h RCA Pre Out -> Subwoofer
I can only turn the sub volume down, but not up, doesn't it all depend on the volume of the denon?
Zek
Yes, but if you increase the volume on the subwoofer, then adjust it with A10h, then you will be able to increase and decrease the volume of the sub.
Jimbob54
What gain setting do you have the sabaj on? I think h1 is unity so won't amplify anything.
M
musica
should I set the sub's volume knob to maximum ?
denon amplifier 50 watt rms for channel sub 200 watt rms
Chrispy
PNW
The wattage of the amps involved isn't particularly going to tell you anything. You may have to fool around with the gain structure a bit to find something to allow the arbitrary change of sub level within a range you find useful....
