All interconnects and speaker cables made with Canare wire. Connectors are all Neutrik except for the locking banana plugs at the speaker inputs.
calm your titties.. I was casually asking himThe lengths? Pretty easy to gauge by eye.
Dude answered the OP, dont think he made any outrageous claims about his choices. Cool your jets.
My tiddies are at peace thanks. Not one for the usual getting to know you chit chat, are you?calm your titties.. I was casually asking him
$100
Totally agree! DH Labs stuff is pretty cheap however.. and it's silver-coated (as far as I know..) so not fully silver. I use their speaker cable because a 10 foot cable has 21.5pf per foot which is super low.It does: Ka-ching.
- Rich
But what is there not to like in a power cord?If you don't like your power cord you can get a hospital grade shielded power cord that handles 15 amps for <$15
Is there a measurable improvement ?Totally agree! DH Labs stuff is pretty cheap however.. and it's silver-coated (as far as I know..) so not fully silver. I use their speaker cable because a 10 foot cable has 21.5pf per foot which is super low.
Well a poorly designed cable without proper shielding will emit rf noise. THis can intefere with other electronics that is why Hospital; grade cables exist.
Where do you buy the hospital cables for <15 at? I need a couple power cables and that's cheap enough that I might as well get one.
Are there any reasonably priced "pretty" speaker cables? I am using Amazon Basics 16 awg and would like to get something that looks a little nicer for the more visible cables. Unfortunately, it seems that all the cables with attractive sleeves are the super-expensive "audiophile" cables. Any ideas where I can get something like this?
I realize this sounds totally insane, but Monoprice now lists them. They start at 3' & 10A for... $0.86, quantity 1.You can search Amazon for google 1 example
https://www.amazon.com/CableWholesa...spital+grade+power+cord&qid=1591668115&sr=8-4
I've also had good luck with this seller: Nakamichi / Canare Star Quad 4S11 Gold Banana Plugs Speaker Cable. Great quality, well-built, good parts and price.
I bought some cheap RCA plugs from Farnell a while ago and was surprised to find a Nakamichi logo on them. They're actually not that bad (gold plated, good fit, metal housing), but I'm under no illusion that they have anything to do with the real Nakamichi brand.Nakamichi does not make banana plugs. Those are some cheap Chinese plugs with the Nakamichi name printed on them. What's left of Nakamichi (someone probably bought the name) only makes soundbars.
