Auditory Cortex
- Joined
- Feb 3, 2024
- Messages
- 19
- Likes
- 16
Adam Audio T7V
I don't have that but do have an A7V here for testing.Adam Audio T7V
Which model you suggesting?I would like to see some anechoic Spins of the V series by Swissonic, someone shared a spliced gated+ground plane measurements of the V5, V7 and V8, and they all seem fairly decent, so I'm curious how they would do on the Klippel NFS.
The V5s, as those are the most affordable and likely easier to integrate into a set up for most due to it's smaller size.Which model you suggesting?
audiosciencereview.com
And the V5s are in sale this year for 80€ a piece, few months ago the V8s were on sale for 100€ a piece.The measurements that I was referring to are on this post, if you'd like to have a look.![]()
Swissonic A305
Hello, thomann just released a new small studio monitor Swissonic A305 5" woofer 100$ Might be an interesting price performance candidate. Best Thomasaudiosciencereview.com
It's interesting to see how it measures because a pair of the T7V is only 350€, while a pair of the A7V is 1270€ a pairAdam Audio T7V
These products look great on paper, certainly compromises were made to hit the value price point they are at. Would love to see a review!Fluid Audio FX50 v2 - 143$ / 155€
Fluid Audio FX80 v2 - 193$ / 209 €
They both look interesting, coaxials with small waveguides, front port, dip switches on the back, and reasonably low price.
Though i'm more curious about the 8 inch ones, same goes for the Swissonic A308 and Swissonic V8 and Presonus Eris Studio 8, they're all around / below 200€ per piece.
Fluid Audio FX50 was reviewed here in ASR.Fluid Audio FX50 v2 - 143$ / 155€
www.audiosciencereview.com
I'd like to see measurements of the larger V8. Erin has already tested the smaller A305 and A306; the A and V series share the same woofer, and the V5 isn't even available as of this poast. Measuring the V8 is a two for one of obtaining a measurement of the larger 8 inch woofer as well as answering @SivKiv's query on diffraction.Which model you suggesting?
Oh, the V5 is unavailable now? Bummer......I'd like to see measurements of the larger V8. Erin has already tested the smaller A305 and A306; the A and V series share the same woofer, and the V5 isn't even available as of this poast. Measuring the V8 is a two for one of obtaining a measurement of the larger 8 inch woofer as well as answering @SivKiv's query on diffraction.
The X8 is also an option but higher priced and less relevant to the meta discussion.
Did you review this? I can't find it on the forum.I bought the HS8 to test.
