What are your top 3 IEM ?
How do you like the origin?
It is a very special IEM. The way they tuned that DD it resonates in the deep bass while at the same time providing solid mid bass. There is physicality there that my other IEMs don't have. the mids are enhanced by the bone conductor driver and the treble is smooth even if elevated to balance out the strong bass.
I use it for EDM and House music to get that big club PA feel. But also, it goes great with 70's rock and pop music that was mixed with bass back in the mix. It makes it sound full and more in line with modern productions. Classic AC/DC sounds so much better on Origin than your typical neutrally tuned IEMs. There is that low end push and power that fits the music perfectly.
I don't use it with acoustic instruments recordings, like jazz or singer songwriter type of style because it tends to make them sound too bass heavy. For that music I will put on one of the other two sets I listed.
I found an EQ setting for the Origin that pushes the vocal range centered around 1.5kHz forward and lowers the 5-6kHz band a bit, much like Elysian does in many of their models. I enjoy it very much with that EQ in place.
Nice. Appreciate the reply. I waited in line last CJ Dallas but never got to hear one.
Do you use EQ on all of your IEMs? I don't on my wired IEMs but I do on my noble wireless ones. The app is really nice and makes the adjustments easy. C
Yes, I have a couple of portable DACs with PEQ and they have my preferred EQ per IEM stored in them. For the Apostle and V16 it's very minimal. Just shelving EQ for personal bass and treble preference, and then it's only 2dB. On my other IEMs I would use multiple bands to force the midrange to behave.
Which Noble wireless do you have? EDIT: Nevermind, I see in your signature.
I have the mystique and the prestige encore (black).
Updated my signature.
With EQ, the mystique is really good as long as I am using aptx adaptive. The encore has LDAC and sounds much fuller and closer to wired.
