Westsounds
- Joined
- Jan 10, 2020
- Messages
- 214
- Likes
- 102
One I can think of is the more it costs or the hype behind it seriously doesn't mean the better the music gets.
hear! hear!> What are the things you wish you knew when starting out in this hobby?
That most hifi-magazines are glorious advertisement peddlers, expensive doesn't equate good, subjective tests mean zilch and that the industry is full of shysters. All the better that ASR exists.
Like theseThat's all I can think for now
- CD quality is enough
- A well mastered CD can sound better then a 192/24 version
- An outside analog DAC is better than any Digital input on an amp (via Pure Direct Modes).
- Most SACDs are just DXD
- MQA is a joke
- HDMI for music is just bad in general.
- An amp that can output 16bit content well is more important then if it can accept & handle anything above 44.1khz.
- Most FLACs on streaming services are "dynamically compressed" and have poor QC.
- John Darko & Hans Beekhuyzen are jackasses
- CDs are cheaper and sound better than there record counterparts
I don't wish to put words into @ThatM1key's mouth, but I assume that he meant audio over HDMI IIS - something that is a bit of a hack at best.I'll take your word for it. But the sounds (music) coming from my gaming systems to my TV to hifi sound pretty good to me.
This is my belief also. Which is kind of in a way why I'm against buying expensive powered (or activitie) speakers actually.leading me to believe that electronics don't really matter much as long as it isn't downright flawed in some way
I don't know what HDMI IIS is. What I meant by that was PC to AVR using an HDMI cable.I don't wish to put words into @ThatM1key's mouth, but I assume that he meant audio over HDMI IIS - something that is a bit of a hack at best.
Personally, I wish that I had opted for active speakers earlier, or at least spent less on electronics.
I mentioned in another thread that I had opted for NC400 amplifiers due to them being more or less endgame from an objective perspective (they are still up there in the SINAD charts, no?), whilst being attainable on my budget - endgame speakers to match would come later when I could afford that. Well, I don't know how the amps in my new active speakers measure, but I guess that they would measure quite a bit worse than the NC400s. Yet, the sound that comes out of these speakers is better in every way compared to my previous ones, leading me to believe that electronics don't really matter much as long as it isn't downright flawed in some way.
I know there's some AVR's that have good digital DAC's but one's I experienced sound better via analog (using an DAC) than HDMI/SPDIF In, both cases in Pure Direct Mode's. In term's of using Room EQ, the on-board DAC is gonna sound better due to that major digitization and that digital "workspace" for analog inputs ranges from 44.1khz to 96khz depending on your AVR, which results in a degraded signal.Hmm, not sure a DAC is a DAC. I'm sure there are some good ones in amplifiers to match a good external.
I'm don't know how the process goes, but I think its DSD (Capture process) to DXD [PCM 352.8khz 24bit] (Edit process) to DSD (Final release). Some SACDs are even just 44.1khz 16bit or even 96khz 24bit converted to DSD.I'll take your word for it.
I should've explained that point better too. Old records prior to the 1970s didn't use digital master and were using "pure" analog masters. 1980s and above used digital masters. I'm gonna say this right out of the gate, there is nothing wrong using digital masters. The problem I have with records is mainly today's. A good chunk of todays records use the same master as the CD, so efficiently that means paying 2x-3x over the CD to have a inferior version & experience because its a novelty. Personally I didn't like the whole record playing experience because the CD always sounded more better for less effort & money. If you like record's that great. It's great seeing people be interested in hobbies I used to love.Hmm. Probably superior yes but I do like the sound of vinyl. It's does something CD's struggle to do no matter what DACs used.
I 2nd this. Going with active speakers means your limiting your upgrade choices. Instead of upgrading a piece of your setup, now you gotta replace the whole active speakers or go out and build a setup with separated components.This is my belief also. Which is kind of in a way why I'm against buying expensive powered (or activitie) speakers actually.
I see, I thought that you meant this.I don't know what HDMI IIS is. What I meant by that was PC to AVR using an HDMI cable.
True, but if your position is that the electronics do not matter (to a point) - does the separate boxes upgrade path mean anything in the end?I 2nd this. Going with active speakers means your limiting your upgrade choices. Instead of upgrading a piece of your setup, now you gotta replace the whole active speakers or go out and build a setup with separated components.
Electronics do matter. There is active speakers are built good all 'round but there is the "What If's". What If the amp dies, what if the drivers die, etc. That's why I like separating things instead having all-in-ones machines like AVR's & Active speakers.True, but if your position is that the electronics do not matter (to a point) - does the separate boxes upgrade path mean anything in the end?
On the streaming services, from my listening Apple Music is clearly doing something to their content to make it louder (which supports your view on being compressed).Like these
I'd agree. Redbook done well is the best we've ever had it and all we need.
Totally agree
I think it probably is but people still 'believe' it sounds better
- MQA is a joke
I had no idea. Thanks
No idea again. Thanks
Yes! 100%
Forget about upgrade. Change if faulty or needed would have been a better way of putting it. Or if you just want more power,features, tubes....whatever.I see, I thought that you meant this.
