I have.
But you seem to have it to....
If you drive a car with 800Hp and one with 80Hp and you drive at normal hing way speed for an hour i’m very sure the one with the bigger motor will uses more Flue...
So this is not in any way shape or form telling if they have vastly different power ratings.
It is the power used from the AC outlet that determines consumption, not the power rating. That is where I ACTUALLY measured kWh for the whole system including the Nakamichi preamp/tuner used to drive all four (4) power amplifiers.
BTW, the IcePower 125ASX2 power amplifier module is only rated at 65 Watts Output per channel into 8 ohms. Don't be confused by the ambitious 125 Watt Output per channel rating that only pertains to 4 ohms. The speakers I used for the measurements that I ACTUALLY made are nominal 8 ohms impedance. The two Class AB power amplifiers are rated at 70 Watts Output per channel into 8 ohms, so they have the same output rating as the Class D power amplifier. They both only used a few pennies more power per month than the Class D power amplifier.
The pure Class A power amplifier is rated lower in power output but was played every bit as loud as the other amplifiers, over the same speakers. It is a constant bias pure Class A power amplifier whose power usage does not change one bit between idle and full volume, and that's just the way pure Class A works. Yes, compared to the other amplifiers, all playing over the same relatively inefficient speakers at the same moderately high volume level (loud) the Class A power amplifier does use more power - to the tune of the cost of one cup of Starbucks coffee per month. That "inefficiency" goes into room heating - meaning that you can turn down your space heater a little bit and save some energy there.
This whole green thing is so over-hyped! Next you'll tell me I didn't ski on a glacier two years ago (which I did in early October at the end of the summer in Austria), or that glaciers on Earth don't mean we're still in an Ice Age. Let's stick to the facts/measurements and not the theories and politics.
