What are the options for a low-budget stage 6-channel power amplifier?(not surround use)
Richarrd
this will be used in a bar, and high fidelity is not necessary, but the output power needs to be high. I will use it to drive 10 JBL Control X speakers, placed in various corners of a 60 square meter space. Perhaps it needs to be divided into two units? For the subwoofer, I initially plan to use an active one.
any good options? thank you!
Maybe this thread will be helpful?
thank you!
You want a power amp only? Or does it need other features?
ps Why 6 ch and not 10ch of amp?
I have some of those speakers, they are great for what they are, but not much bass, especially outside. You will want one really serious sub or a few pretty stout ones.
I don't think you need a ton of power for them, nor will they take a ton of power, they top out at 100w. 10 of them in that space should be pretty loud but they are not real PAs by any means.
BTW where are you getting them? I think they were discontinued over a year ago.
Thanks! Yes, I made a mistake—I just planned to acquire them, thinking it would be easy to find many second-hand ones, but it's actually not that simple. It's hard to find another suitable one now, but I'm still working on it.
Just some basic functions would suffice, but 10 channels would be even better. I don't have much experience in this area yet—I'm still learning.
