reasonable weight since it is portable, DSP/PEQ, ample voltage delivery for my IEMs (which is not a lot), super low to near zero output impedance. 4.4mm and 3.5mm outputs specificallywhat are the main things you would be looking for if you spent 1000 usd on a portable headphone amp? is it sinad? is it power? and based on whats most important to you which amps would you get at this price point?
what price would you pay, and what features would you be willing to sacraficeI would never pay that much personally. Then again not a huge headphone/iem fan, but have had great results a variety of other amp routes. You're overthinking it depending how deaf you might want to be perhaps.....
what amp would you get (If you had the csdh or if you do have the cash)reasonable weight since it is portable, DSP/PEQ, ample voltage delivery for my IEMs (which is not a lot), super low to near zero output impedance. 4.4mm and 3.5mm outputs specifically
I already have it. the Qudelix 5K since I use IEMs and have no use for excess voltage and power delivery.what amp would you get (If you had the csdh or if you do have the cash)
so would you look more in the range of 700-800 usd with, idk 123db sinad?I see no reason to spend 1K on a portable. If one does, it should have superb SINAD, gobs of power, hopefully some DSP, and the ability to either serve as stand-alone DAC or preamp to a main or desktop system. USB, Optical and Coax inputs would be nice. And an analog input would good, too.
My old iFi iDSD Black has almost all of this. No longer SOA but works quite well and I have yet to dump it for a new model. Kind of big, though. The new XDSD Gryphon looks like a winner. Plenty of other good to great ones out there for way south of 1K. Save enough and get some decent IEMs.
what are the main things you would be looking for if you spent 1000 usd on a portable headphone amp? …
A stack of change.
Cook, clean, make good conversation.
I already have a couple phones/tablets, and they already work well with my headphones/iems, so I'd just use those and save the $$. Are battery powered headphone amps for portability particularly expensive?what price would you pay, and what features would you be willing to sacrafice
I'd be looking for an 80-90% discount on the price.what are the main things you would be looking for if you spent 1000 usd on a portable headphone amp? is it sinad? is it power? and based on whats most important to you which amps would you get at this price point?
