What are the key characteristics for a good gaming headphone? (ignore the microphone)
Depends what you want from gamming, in my oppinion:
Competitive gamming -> Huge soundstage for better positioning, clear separation, good mids and highs with recessed bass to better positioning and sound recognition
Just fun factor gamming for shooting -> As much bass as possible and as low as possible to enjoy the booooom in the purest form xD, if you get the "wall of sound" effect and the "kick in the chest (in this case head)" the better.
The rest of gamming -> A balanced monitor studio that follow more or less the curve
Refered to the Shure SRH440, i don't have them and talk only from second hand, but all that i've heard make me doubt about being a good gamming headphone.
The comfort is going to be a major thing after you wear them for hours at a time. Leather/leatherette is more sticky than velour. On a hot summers day a sweaty pair of headphones is not pleasant. There are open and closed designs. The open designs apparently have air going through those vents and that helps keep them dry as the body heat rises out of the holes. Sound isolation is another thing. Can the people around you hear the audio and is it a bother for them. If so then a open design is not for you. Closed design headphones do not emit much sound energy.
I use a Sennheiser HD598SR (Open design with velour pads.) and a Sennheiser Game One (Open design with velour pads.). The Game One has the renowned microphone in this series of headphones and it works very well. They both have velour pads on the earmuffs. I don't think I could stand leather/leatherette pads in the summertime. Also take note that the cable is removable and replaceable. You want a cable that is not microphonic too. Some cables when impacting or rubbing against things cause sound in the earpiece(s). It sounds horrible and is very annoying. It is more common than some people think. My Sennheiser headphones have no microphonics occurring.
Oh and coily cords cause knots to form and kinks in the wire. I like straight wires from my headphones. The Sennheisers use straight wires.
I think the ability to extract ambient/background sounds is pretty important as well as an accurate "3D" imaging (of course this is built in brain from stereo but some headphones seem better at it than others) . I am not a competitive gamer (I tested it on FFXIV and solo games, stereo no surround effect) but between HD560S, AKG K712 Pro and Denon D5200 I own, the Denon one is unbelievably good at it (and this is the same in music). AKG is wide but not that "accurate", HD 560S too narrow and blurred.
Gaming headphones are different right? If you are a professional gamer you must use special headphones made for gaming. I don't know your budget range but I can give you a recommendation - Check out here - Best Open Back Headphones For Gaming
Hope it will be helpful. Also I will recommend you to use Sennheiser Headphones For Gaming. Its also great
I suggest you contribute to the conversation, rather than shilling your own website (as you've done in 5 posts already since joining ASR today).
Did you change the cable for the Game One? I have the closed H6Pro, which seemingly has the same one, and there's a lot of microphonics. Considered buying some third party TRRS 2.5mm to 3.5mm cable as a replacement, do you think it's compatible? I've heard of people changing to ATH M50X cables for example, while others say the H6Pro cable isn't replaceable...
I donated the Sennheiser GameONE headphones to amirm for testing.
Funny enough I sent the headphones and the long cable to amirm and forgot to include the short 1m 3.5mm cable. So its sitting here on my printer and never to be used again. If you want the 1m Sennheiser cable you can have it.
I appreciate the thought but it seems to be the same cable I'm having issues with (https://www.audiosciencereview.com/forum/index.php?threads/h6pro-microphonics-problem.40067/). Wish there was a way to replace the cable with a rubber one, but from the responses it seems it's proprietary...
I think Sennheiser dropped the ball on the GameONE cable by wrapping it in that fabric sheath. MY Sennheiser HD598SR headphones have a silicon feeling cable and it is silent. No micro phonics at all.
I'm also in the search for good headphones for gaming and was wondering this myself.
What I found so far is stated already here in the 2nd post - it really depends on what type of gaming you need headphones for.
In my case, I play mostly single player, so I need fun headphones.
I currently use Audio-Technica ATH-AD900X and they don't fit the bill. They have great soundstage, decent imaging but they are mostly flat-ish and boring, at least when ran through an AVR (which prob. muddies the sound further).
So now I'm looking for some fun headphones for single player gaming with the following characteristics:
- open-back
- comfortable
- close to Harman target curve (with a lot of bass, but not too much upper bass)
- decent soundstage
- decent clarity and resolution
- run well with crappy headphone out of AVR (usually high output impedance), so prob. the headphones have to have high output impedance
-100-250$ price range
So far with my Denon X3300 AVR (no option to use a separate DAC and/or headphone amp in this setup unfortunately) I tested:
- Audio-Technica - ATH-AD900X - good soundstage, but too flat and boring, lack of bass; comfort is pretty good
- Beyerdynamic DT-770 Pro 80 Ohm - great dynamics, great bass, fun sound and great comfort; abysmall soundstage and some clarity and resolution issues making highs sound grainy and overall making the sound weird in terms of different sounds blending with each other, can't explain it really)
- Focal Clear MG Pro - great dynamics, great clarity, pretty good comfort; only downsides are the small soundstage and the price (I use these headphones for music listening in my other setup, so can't really use them long term for gaming)
- Audeze LCD-2 (pre-fazor) - good bass, not as good as on the Clear MG Pro though, decent soundstage, somewhat muddy sound, clarity and resolution are just OK-ish; horrible comfort, my head hurts after 1h session;
- Philips Fidelio X2 - good bass, decent clarity, somewhat small soundstage, but still OK-ish, sound is a bit muddy yet grainy somehow;
I have tested all of these headphones with various other amps and DACs and they sound noticeably worse through the AVR. Probably the only ones that don't suffer that much are the Clear MG Pro and to some extent the DT 770 Pro.
So I got two questions:
-what is that AVR's headphone doing so terrible wrong, except for the potentially high headphone output impedance? What other headphones might work better with the AVR? I did a quick test sometime ago with the Fidelio X2, running the same song on my AVR and a Cayin N3 portable player and I was switching fast between them (volume matched mostly) - the sound out of the Cayin was noticeably better; not "night and day", but still easy to tell. So def. the AVR is messing up something, prob. that high output impedance, which still doesn't explain why the 80 Ohm Beyerdynamic is also not that great when ran through the AVR, compared to my separates rig.
- what other headphones could you recommend that meet most of my criteria listed above?
