Wharfedale Elysian 4
I wouldn't buy an upper range Wharfedale speaker after what I see here on ASR.
Beautiful cabinets from the outside. That's the positive.
The capacitances of the crossovers look ok, the inductances are not high quality.
The drivers are mid-range.
The internal finish with cardboard as the cabinet material for the midrange and for the bass reflex ports is a hallmark of very cheap loudspeakers.
Shame on you Wharfedale.
This is not Elysium, this is Hades
Meant to add, my jade's and I think all the others have a cardboard enclosure for the midrang/upper midrange :(
While it looks cheap (I’m feeling it as well as owner of the Evo 4.2 and Super Linton) as long as it does the Job ?
When you look at the crossover and absorber material used in the original 60/70s loudspeakers you will have a laugh.
This is inside a modern Harbeth loudspeaker:
Uh, didn't check, might do it later, I hope it's not cardboard :facepalm:
When can we start calling this by its proper name, a scam? :rolleyes:
They sell 10K USD speaker with specs that have nothing to do with reality, they talk about "quality of construction" and you find cardboard port, cheap parts and shoddy workmanship.
Sympathies. Certainly looks the part on the outside.
Hmm quess lots of the money goes in the cabinet with speakers like that.
Check out what other expensive speakers look on the inside.. sure the renders will look different. But im not convinced a plastic port would beat a cardboard port.
So does it matter ?
The woofers seem to cost 100 bucks per piece for normal people. So probably 500-600 bucks per speaker for everything minus the cabinet ?
this is why retailers are able to give big discounts and everybody still makes money.
My retailer sold me the wharfedale super Linton for 1400 euro (retail price 2000 euro) and he still made money on them (that’s including shipping and tax).
I can only imagine what the profit margin on the Elysian has to be.
I have seen some Dali speakers and other brands that manufacture in china.. and it’s not really that different from wharfedale.
Would like to know what a really expensive or BW speaker looks on the inside :)
But on the plus side..when I compare the difference between a Evo 4.2 with a Aura speaker .. those are speakers I would be interested in modding :)
Might do that with my EVo 4.2 as experiment.
Here is another 2000 GBP bookshelf
The Elysian 4 are 8500 euro with 20% VAT included in there. Seems about right when you factor in that dealers are able to give 30% discount on that and still make money.
I would probably get big Bookshelves instead with 2 subwoofers.
On this website you can see some of the drivers used in more expensive loudspeakers.
Are you pleased with your evo 4.2? How much did you pay for it?
I got them currently stored away. I got them a couple of years ago for 640 euro .
With subwoofer and EQ the Evo 4.2 are actually pretty good :)
Currently using the Super Linton.
This is inside a modern Harbeth loudspeaker:View attachment 445690
Made in the UK rather than China in arguably FAR smaller batch quantities and with higher production/labour costs as a result no doubt. I'd suggest the panel damping and foam lining was *very* carefully selected too and not just any old stuff pulled off a shelf and quickly stuck in. It's already been determined I believe, that fancy-foo caps are just that - basically a mugs eyeful for the unwary ;)
Chinese production and high import profits have fooled us hugely I fear and costs of enclosures, components and tooling are horrendous over these parts I'm told (by a small-scale speaker maker). I doubt Harbeth will shift production to China any time soon ;)
It's all in the eyes, I tell ye, not the sound quality... :facepalm:
Elyisan 4
Red - Bass reflex plate with front and back plugs (as it comes from factory)
Yellow - Without bass reflex plate, going directly into carpet
Orange - Bass reflex plate without front and back plugs
I like most the Orange option, still needs a sub but, with +12dB at 40Hz it can sometimes be ok.
I think you may have an issue with yours speakers or setup. My Elysian 4’s are seriously full sounding and excellent bass and for most music I don’t need a sub- only electronic very deep stuff. If I set my sub (KEF k92) higher than 40Hz it’s too much - my ears confirm they are definitely 30 Hz in room. Large room. 1m from side wall. Dirac testing does confirm sub-80Hz responses as well (at least in my room)
My friend, your own measurements show HUGE drop in bass, you're DSP-ing them back into something acceptable:
Hi. I don’t actually use the Dirac but was only experimenting with it (is massively narrows soundscape and headroom for vinyl). The drop below 0 in bass only occurs at 30Hz for 1 and 40Hz for another speaker (room effect) with a general up and down- likely room effect-and average decline below 80hz from what is actually a pretty elevated amount (not a massive drop). In room (and at ports) there is absolutely masses of bass I promise you! My sub only kicks in below 40Hz as it’s just not needed. These are the best speakers I’ve ever heard (not that I’ve listened to mega $ ones!)
I also have the Elysian 4 paired to a Hegel H600. The front and back of the port is blocked and slideway's it's open, same as in the OP's photos. I am not facing any issues with the bass though.
Haven't done any measurements but I can certainly play sinewave up to 30 hz and have the house shaking.
I recently renovated my house and also treated the living room using a professional. After the treatment, the bass is slightly less than what it used to, but it's clearer even though the speakers are placed at the exact same position.
Will be back with measurements at some point.
PS. The OP used the bass terminals from the bi-amp terminals and since he could hear high frequencies he deduced that the woofers were playing the sound. I think the logic is flawed here. The crossover can still provide some sound to the tweeter even if you are connected only to the bass terminals.
No it cannot, how could it? Cables do not go from bass crossover to the mid/highs.
Did some tests and you are right. The 8 inch woofers cross over quite high.
Did some really fast measurements with Spectroid app on Android and a sine swipe that are certainly not in par to the standards of ASR but they are informative. Look at the red line. The app does not do smoothing.
low (bass) binding post, on sitting position:
low binding post on sitting position
high binding post, on sitting position:
both binding posts on sitting position:
both binding posts, on sitting position:
both binding posts, near speaker position:
both binding posts under speake
The speaker plays linearly up to 56 Hz and then drops. You can still hear/feel up to 30 Hz but it's quite lower.
low binding post on sitting position:
high binding post on sitting position:
both binding posts under speaker:
I told you, these speakers have no bass, at all. I have no idea why they made such big boxes if they are not going to play bass. :)
By the way, what does "binding posts under speaker" mean?
I hope some day Erin or Amir will review these and let everyone know that either I'm a moron or that Wharfedale is scaming everyone with false advertisement (and all other reviewers are just paid shills.)
P.S.
I have no idea what bass crossover does. Those "8" inch drivers play practically full range and have huge dip below 80Hz.
I'll try disconnecting them from the crossover and seeing how they play on their own. I would not be surprised to see they actually produce real bass.
