Wharfedale Elysian 4
You're doing near-field measurements, like Stereophile.
At the end what counts is how it sounds in a room on the listening position. The result is JimFarrell and I have bass and have the best imaging we ever heard.
you're having bad luck not to have that experience and are bashing those speakers.
And no I don't think Wharfedale measure anechoic, their published specs in the manual specifies in room performance.
page6
And that is also what we see in @amirm review of the Wharfedale EVO 4.1 Review (Speaker), that speaker is rated at 64Hz (-3db), when you see the Klippel Near-field Scanner (NFS) measurement bass is dropping below 100Hz, but when you at the estimated in-room response thet the bass drop is more like the Wharfedale spec.
I would be a great speaker manufacturer. I would simply build a room around all my speakers so that the measurements would be great.
I understand your point...but fromba commercial piint of view, and to have a majority of customers happy, the choice a making a speaker that plays well is probably a smarter choice then making the perfect speaker for an anchoic room that almost nobody has.
Several people owning this speaker participated in this discussion, and they don't have bass issues or imaging issues.
Furtur his near field bass measurement is incorrect as soleone already specified, he needs to measure both drivers separately and the bass reflex port.
page6
I'm sure they used anechoic measurements in development. The reason some manufacturers quote best case 'in room' measurement is because it shows better bass extension and so sells the speaker.
What would I do in my room where I cannot place the speakers anywhere near the front wall? If I didn't appreciate the difference between anechoic and in room measurement I'd end up with big, expensive speakers that had no bass.
This is the reason anechoic is the benchmark guide. Rooms and available placement options differ too much.
I rarely agree with @dcolak, but I appreciate his honest opinions about what he thinks is good or bad in the hi-fi sector.
Personally, I find this much more useful than the usual repetitive mantras of the respective fanboys.
If you're doing near-field measurements then you need to measure the output of the port as a separate entity and add it with the output from the woofers. If you don't do this then you will see a lack of bass. That being said you are quite correct when saying that the enclosures are simply too small for the pair of drivers to work properly. These are not drivers that optimise into small enclosures and need at least 70 litres each for a decent alignment in a ported configuration but you can go as big as 100l if you want to maximise the bass extension. If these speakers are only giving 30-35 litres to each bass driver then it's as if you're using them sealed. The port will be tuned very low and give almost no useful output where you'd ideally want it to be. With the right room reinforcement, room gain, and speaker placement you'll be able to luck in on better extension but it's not a given. Also it's worth pointing out that Scanspeak are known to have some quality control issues when it comes to magnet strength that results in their drivers needing to be used in even bigger boxes than their T/S parameters would indicate.
That being said the drivers are of reasonably high quality, with shorting rings, and attention to detail when it comes to break-up. Correctly implemented they would sound great but with limitations. The biggest limitation being the off-axis of the tweeter. You've already mentioned that the stereo imaging collapses off-axis whereas the JBL Array 1400s are fantastic. This is of no surprise. The JBLs use waveguide loading to provide constant directivity and a hallmark of that is stable imaging across a wide range of listening positions. A speaker that uses naked domes/cones/foils (ie tweeters without waveguides) simply cannot compete.
Wharfdale should have allocated most of the speakers upper volume to the bass instead of the midrange and tweeter. They should also have only used a single bass driver and given it the volume necessary to allow it to have deep bass. The alternative would have been to use completely different bass drivers but the vast majority of 8" drivers (and these are what typically qualify as 8" drivers, the midrange are 5") need bigger than 30-35 litres ported.
The bad news is that this is a typical trend across manufacturers although none have been as bad as this Wharfdale speaker in my experience. Most people prefer smaller, narrower, speakers. The trend has been for manufacturers to use multiple smaller bass units in relatively small cabinets. Most of them optimise into what's known as extended bass shelf alignments. This is what Wharfdale tried to do but failed at.
The bass output of the driver extends here down to 70Hz, the upper black line, where it then falls off. The port then provides additional output down at a low tuning frequency of 25Hz. This is the extended bass shelf as the frequency response is supposed to look like an additional separate extension of the bass that is shelved down in level Vs the proper bass output from the driver. The idea is that room gain compensates for this shelved down response and you end up with a flat response in room. That's if you design the EBS alignment properly. Wharfdale have not done this as a 15dB shelf is far too excessive.
The JBL array 1400s actually do this too but they do it properly.
Here we have the same lower bass response shape but done in the correct way as there's only a fall off of around 4dB between where the true bass output and the extended bass shelf takes over. This is something room gain can work with.
Here's another example of a KEF speaker doing an EBS alignment right.
And another KEF.
KEF R11 Meta Floorstanding Tower Stereo Speaker frequency response measurement.png
Here is Revel trying the same thing but falling into the same trap as the Wharfdale here. They are trying to cram 3 8" drivers into too small of a space. There's the smallest hint at an EBS but really it's too far down to work properly although it's not quite as bad as the Wharfdale.
Revel F328Be CEA-2034 Spinorama Early Reflections Frequency Response Measurements.png
Revel actually do this with the Salon 2's and pull it off perfectly.
There was some method behind Wharfdale's madness it was just implemented poorly as you know the JBLs 1400s and Salon 2s can do fantastic bass.
One of the good things about the EBS is that because the port tuning is low in frequency you can EQ it strongly without risking the driver unloading too much. You should be able to EQ the Wharfdale's bass without it sounding strange. It's odd that you encountered this earlier on but I would encourage you to try again. There is no way to fix this really. If you are using subwoofers then I would recommend you plug the ports up to provide a proper 12dB/octave roll off.
Thank you man, I though I was going crazy, it was so obvious. It's a lesson learned for me, all those "reviewers" should not be in the business.
My problem with subs right now is that they cannot keep up with the Elysians, SPL wise (JBL LSR310S).
I'll probably switch subs for better ones and call it a day.
In the mean while, I was bit by classic JBL bug, behold, JBL Studio 4412's.
There is something magical about them, can't stop listening to the music.
The stereo image is rock solid, width, height, depth... very surprised by the whole serie.
Did some measurements too, that twitter is so smooth up to 16 Khz (I did have to refoam the tweeters, otherwise they peak at 9-10Khz).
