Wharfedale Diamond 220 Budget Speaker Review
I completely agree with that. :)
Wharfedale Diamond 220.Very good sound in relation for the little money they cost. Without subwoofers, I wouldn't use them, but I think they have the potential to facilitate a smooth sub-speaker integration.
A good sub-speaker integration, a little EQ (mainly probably for the sub), if necessary fix the acoustics in the listening room and you will go a long way in getting a good sound. :D
It depends a bit on the use case. In a very basic system like in our garden/guest room it works perfectly fine without a subwoofer. The same would apply in a small room. Adding a sub (or two) more than doubles the budget, in which case I would go for the Elac Debut Reference 6.2
Absolutely, it depends. :)
I'll take them to my apartment later. Completely different conditions. In the cottage no neighbors to consider. A semi-open solution for the rooms, so a bigger listening room than my living/listening room in the apartment.
In the cabin, I take the opportunity to play at as high a volume as my ears can handle. I don't have that kind of high volume, very pumping bass (it is about satisfying the need ;)), preferably low distortion at high SPL so as not to tire the ears need in the city.:)
Edit:
After positioning them better. Fixed with better sub-speaker integration, I have to say they are growing. :D I have listened to music for hours and hours with them. That to me is the best indicator to give them a big thumbs up. As extra speakers for the bedroom, some summer house (not too big listening room) they are a very good choice. They might be better than my XTZ Tune 4. I'll compare them both against each other when I bring them to my apartment.
I bought mine couple of weeks ago and I can't wrap my head around how good they are even for MSRP, let alone 90€ I paid for them, in mint condition.
Comparing them to Dynaudio Excite x12 and Dali Oberon 5, hooked to Marantz PM7004.
Easily beats them in value for the price.
Of course sounds thinner in comparison, but hey, for the price that's perfect little speaker and more you listen to them, more they hook you up.
Also tried them as speakers for my Roland piano and they are actually more convincing piano speakers than the other two.
They grow. I have listened to them a lot. After a lot of tinkering with the integration sub - Wharfedale Diamond 220 regarding placement and sensible HP-LP filter settings, I can say with quite a bit of certainty that a pair of used 220s are a hell of a bang for the buck. :D
It wouldn't give much better sound if I were to invest in really expensive sub and or speakers compared to the sub-220 setup I have if I now would: Tinker with the room acoustics (reasonable amount of furniture, carpets, well-placed diffusers/absorbers) plus EQ (mainly in the lower frequency registers).
(I'm shying away from EQ at the moment because I don't have a decent computer, with Windows, that I can dedicate to streaming, to crank up Equalizer APO with)
However, to be fair and to keep things in perspective, my other set of small speakers, the Harbeth P3ESR used in my study, are quite a bit better, with greater clarity and precision. Of course, that is to be expected since the Harbeths are a lot more expensive.
Yeah, like 10 times more expensive )))
It would be a shame for them not to beat 300$ wharfs
With the same conditions, sure so it could be BUT 220 with sub in an acoustically sensible room plus EQ vs Harbeth P3ESR without that I'm convinced the 220 would come out victorious.
Harbeth P3ESR with its 5 inch bass driver, nothing bad about it as all other small speakers with small woofers need a sub I think. But even with the sub but without sensible room acoustics and EQ I would prefer the 220.
Harbeth P3ESR:
The rise in the upper bass will be, as usual, due to the nearfield measurement assuming a 2pi environment; without that bump, the speaker's low frequencies will be down by 6dB at the woofer's tuning frequency of 70Hz.
In a more reasonable price comparison with the 220, this DIY gives them a match:
OT
If you build a pair of Mechano23s, you can still, when you are building, add two bass modules and make it a three-way speaker.:)
I first used my Harbeths with a sub, but then decided that it was not worth it in my small under 20 sqm study. Of course, adding a sub to the Diamonds extends their response, but the Harbeths have a much clearer midrange. I like subs, but not in small rooms like this - the P3s extend pretty low and give a quite realistic picture in the near field as on my desk. As an experiment I have also tried them in my main system, highpassed at 80 Hz and with three equalized subwoofers (instead of the Quad 2805s). They were impressively realistic, although they did not quite fill the large 70 sqm listening room.
Do you think it's because of the dip the 220 has around 2kHz? I did a quick and dirty EQ via an app and cranked up a bit at 2kHz. Obviously not optimal, but better than without that EQ, I think.
Wharfedale Diamond 220 Budget Speaker spinorama cta-2034 early window Audio Measurements.pngScreenshot_2025-01-12_141832.jpg
View attachment 420523View attachment 420524
I don't know, but I am sure there is rather more to it. By the way, the Dutch Wharfedale importer now sells them online for 169 euros a pair.
Didn’t expect the grill to make such a huge difference. If so how come focal shapes and genelec 8000s can make it so flat with a grill so close!
Not true, the grilles form a port 1cm long killing the treble response, look at Amir's treble reponse with teeeter grille on & off, it forms a short port effect surrounding the tweeter dome, great treble with no grilles, terrible with grilles, there are 4 grilles, 2 for the tweeters, 2 for the bass/mid units, i own these, without grilles they have a fantastic clean & clear midrange, vocals especially, the tweeter grilles kill these great speakers frequency response, great wothout the grilles, a noticeable improvement with all grilles off
There's horrible chuffing from the port on my pair that rendered them useless for near field, which is my use case. It's probably form the port not being flared on both sides. I never got around to fixing them now I use them as stands for my KEf 350s.
Higher spacers between the port & base help with port chuffing, the ports are cardboard tubes, i painted the outside of the cardboard port tubes with PVA glue making them much harder, less resonant, a ring of draught excluder foam around the bottom of the inside of the ports helps dampen the port chuffing & cleans up the bass a little bit, try 15mm spacers instead of the 10mm spacers provided, available from eBay, Tharbarmer does a video on the 225's he modded on YTube, same tweeters & grilles, 6 1/2" bass/mid drive units on 225"s...higher spacers give more bass, Tharbarmer used 20mm spacers on his 225's, i would try 15mm high spacers on the 220's & maybe 18mm....ps, your Kef 350's sound better on decent solid 3 legged speaker stands filled with Atacama Atabites & expanding foam.....respect
Oh noes. Mine are literally falling apart with loose somethings inside both speakers. One I have diagnosed. The speaker terminal is loose and wiggleable, must access inside to fix. The other one I have no idea. I have been very careful with handling them so they have literally been played to death. Or at least to a well deserved retirement.
I have to commend the consistency, they failed within two days of each other. Well done, Wharfedale.
These have sounded rather well for me, even in my largeish living room (with a subwoofer).
I wonder if the Lady of the House grants me permission to get something like an entry level Ascilab.. if she gets to pick the colour? Should I expect a mighty improvement in sound?
I went from Wharfedales to Ascilabs and found them an enormous improvement
Well, looks like it'll remain a dream for me anyway. Lady asked me to fix them and after about 30 minutes I had tightened eight rattling terminal nuts and an unbelievable 20 front baffle/driver screws that had undone themselves over the years. The rattles are gone. Alrighty then.
Attached image from one of the speakers. They were all loose. One was about to fall off.
You got bumped m8, mine i painted PVA glue on exterior of cardboard port to stiffen them & stop any resonating, nobody can see the port bottom so could have sanded the edges to reduce port noise, cheap door insulation foam, draught excluder, stuck around the inside bottom cm of the port reduces port chuffing, i would have done both tbh, the loose bits will me loose magnetic bolts push on terminals or something on x-over giving a bad resonance, i use epoxy resin to glue down any loose x-over components & pour over the air cored inductors to stop volume vibrating resonance, i solder Chord Clearwater from copper soldering tags on solid Copper banana sockets soldered straight to the drive units terminals using pure copper heat sinks to stop any damage, Canare jumper cables, pure copper banana plugs & spade connectors Gold plated, hardened reflex port in 48hrs after 2 coats PVA glue on port exterior, i use 4 for Dolby Atmos, all modded, no rattles no chuffing, sounds better & a little bit more bass with 8mm spacers...i luv mine, even used as stereo speakers & 2 x SVS SB1000 Pro subwoofers (Gloss White) the Wharfedale 220's used without there grilles as they destroy that beautiful clean midrange & boosts the tweeter in a bad way....there built to a price so sometimes a couple of small mods can make a huge difference to cheapish speakers, i got mine for £120 new each pair (Black Gloss Baffle) excellent Dolby Atmos speakers, very happy now there upgraded, nothing to come loose, port chuffing or rattles of any kind, at least yours were consistent breaking down within such a short time, got same great reviews, especialy the 225 with 6 1/2" bass/mid drive unit.....
I would love me some tinkering like that but toddler years are a bit chaotic to arrange the time:) I did one modification though - I put a rubber seal around the vent in the bottom, removed the spacers and put the bottom plate back. So it is a very much sealed box now. I think I heard some weird boomyness from the vent before and now it is gone.
It could also be my imagination, hearing what I hoped to hear by sealing the box :)
I have a sun room which is going to be utilised as a family room. I bought a discounted Sharp, Roku TV which I must say is fantastic for my needs but the sound coming from it is unbearable. A great excuse for me to get researching for a set of small speakers, cheap enough that I won’t be too upset if/when the children damage them yet something that can also satisfy my Hifi affliction. Found used pair for £90 which I will be pairing with a 3e Audio A5 and a WiiM Ultra. The sun room is a far from ideal acoustic space but the bar for improving the sound of the TV speakers is so low, I am sure to be satisfied regardless.
