Sound
No roomfit (room correction) not much bass, since it lowers the deep voices, there is high room gain = alot of energy around that area where bas starts and the deep voices are
For a, im not rated at 45hz or lower at -6db, bass is good with roomfit, i think 50hz is minus 6-8 db, 75-100 hz a little "warmth" no 7-9-13,knock on wood port noise or anything i can hear that is not realted to the song, with the amoung of bass,extention and quality i wouldn't wanna have a pair of 12.0(i) as a stand alone speaker for nearfield
No roomfit as crappy as some cheap logitech,creative speakers
YMMV but room correction is madatory (at least for me)
Not angled, sound is very pleasant even after room correction, the sound is only a little bright from songs that are bright, there isn't the usually sparkle in the highs in the same way like the B&W 606/607 s1 and s2 or dali zensor,oberon and good full bass
Power, if you don't need to have roomfit or roomperfect or musiccast (yamaha) do as much enhancement in the bass as in my situations to hear bass (you have a good room) bass is good up to 85 % of the power a wiim amp pro has, mine is 85% so when the amp shows 100% it's 85% of the power the amp has + down to 20hz (35 ish might also have been okay) frequency range i used for room correction.
With roomfit (se picture in #398) i wouldn't give it all power (85% volume indicating 100%) with the most bass heavy song like Dub Smoke by Pitch Black just to have clean bass, if room corretion is a few db enhanced play as loud as you like, as long as it sounds clean,no distortion
Spl, party level it's just fine, last 15% from 85% to 100% is where it's get's about small party loud (italiobrothers is approved)
Some complained about uneven tweeter and glue, dirt on the speakers, nothing here
Still don't like the silver ring around the units but more subtle than q acoustics
