last year, i don't have it but also can't use a sub atm. Today it's exactly 4 month ago...and do your ears think there is enough volume after your EQ operation?
Also, didn't you buy a subwoofer recently? I don't remember exactly. If so, you should do the opposite. That is, unload your speakers from operating below 80Hz-100Hz.
I'm not sure I follow. I'm asking about Decibals before they become distorted to hell. The KEF Q line seems to have really high SPL capabilities. Hoping these can be similar.Wharfedael diamond specify it
Generally it's enough 100 watt pr channel
The Wharfedale website states "Peak SPL 96dB" for both the 12.2 and 12.2i models in the specifications. Their sensitivity is 88dB (2.83V @ 1m), which is equivalent to 1W into 8 ohms. The recommended amplifier power is in the range 20–120W. If we go with short-term 100W peaks, then the speakers might be capable of 108 dB SPL, However, that is way above the "Peak SPL 96dB" rating, also in the specifications, which would be achieved with only 6.3W of input power. If using a subwoofer crossed over no lower than 80Hz, the input power from bass transients would be greatly reduced. If we go with 20W of peak input power, which would seem to be a moderately conservative amount, then peak SPLs of around 101dB could be expected.I'm looking at the 12.2i or maybe the 12.3i as front duty for TV and home theater use. They would also be crossed over with a sub at either 80 or 100hz. What kind of volume output can these do?
Wow amazing reply. Thank you.The Wharfedale website states "Peak SPL 96dB" for both the 12.2 and 12.2i models in the specifications. Their sensitivity is 88dB (2.83V @ 1m), which is equivalent to 1W into 8 ohms. The recommended amplifier power is in the range 20–120W. If we go with short-term 100W peaks, then the speakers might be capable of 108 dB SPL, However, that is way above the "Peak SPL 96dB" rating, also in the specifications, which would be achieved with only 6.3W of input power. If using a subwoofer crossed over no lower than 80Hz, the input power from bass transients would be greatly reduced. If we go with 20W of peak input power, which would seem to be a moderately conservative amount, then peak SPLs of around 101dB could be expected.
