If only Neumann made a big (and ported) KH750.Yknow, I don't know. Probably some top end Rhythmik or something.
Unlimited money means you can hire the best necromancers, too.
Well, there is always the KH810.If only Neumann made a big (and ported) KH750.
You lose the room/phase correction facilities, though.Well, there is always the KH810.
Since we're at "money doesn't matter", add a Trinnov boxYou lose the room/phase correction facilities, though.
In such a fantasy scenario I guess I'd cycle through a number of different options. If money were no object selling at a loss to move on to something different wouldn't bother me.
I like it. Maybe just add a level, perhaps underground, with a rotating cylinder in 8 pie slices, a lift, staircase, and listening room in each... with 100V, 120V, and 220V receptacles.You could build a large circular house with each room shaped like a large truncated pie slice, each room having different speakers
DIY, no parallel surfaces anywhere:You could build a large circular house with each room shaped like a large truncated pie slice, each room having different speakers
Altec A5 with 1505 horns/Altec 288 treble drivers and Jean Hiraga's crossover design.
I have heard better, but only at far greater total cost of entry.
If money and space would be no problem. I see no reason why just one pair of speakers should fit to all my requierements.
Remember I said money is no object so pick something even betterAltec A5 with 1505 horns/Altec 288 treble drivers and Jean Hiraga's crossover design.
You're not stuck with anything, space is no object, like I saidOff hand if I were looking for a speaker for my stereo system to fit into a small-medium sized room such as what I'm stuck with.....
Seriously. I already built the best speaker (for my space) I knew how using off-the-shelf drivers. If money were no object, I'd commission new drivers to be built, and work with a team of engineers to design them. First and foremost I need a side-by-side double ribbon: one 60 mm tall, and the other 180-200 mm tall.Why would anyone with unlimited funds settle for something off the shelf?
I second that, if I dont like them then the Focal Grande Utopia.Beolab 90 - interesting technology, interesting design.
